Old 08-20-2012, 09:30 PM   #1
Engine cutting power after hard cornering... Video inside
We experienced a power cut after "Lost Hill" at Buttonwillow last weekend.
Here are the circumstances:
- Power cut only happens when we are going for a fast lap, and "jumping" the berm at the top of the turn; the car is likely momentarily catching air here.
- Fuel was at 75% full
- Does not happen ANYWHERE else on track, even on other turns where catching air is requisite for a fast lap.
- Power cut occurs a few moments AFTER the turn.
Video:
[ame="http://www.youtube.com/watch?v=NYHG_nArnGo"]BRZ cutting power after a corner... - YouTube[/ame]
Old 08-20-2012, 10:02 PM   #2
so26
Drives: Raven FR-S 6MT
Maybe you could use a Bluetooth OBDII Diagnostic Scanner during your run and diagnose the issue.
BTW, I take it that both traction and stability control are turned off.
so26 is offline   Reply With Quote
Old 08-20-2012, 11:16 PM   #3
Yes, all aids are off (although there's still that light that blinks under trail braking that we haven't yet figured out...)
We have a Aim Solo DL, but it can't read anything from the ODBII port on the BRZ
Old 08-21-2012, 07:25 AM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
i know people have had some success with the bluetooth OBD2 adapters paired to a smartphone for datalogging.
Old 08-21-2012, 08:06 AM   #5
d1ck
Drives: Black 2013 FRS
I've got a chinese bluetooth adapter and the Torque app on my android phone and I can confirm it works great. Even shows AFR's, although it seems like the stock sensor only reads down as low as 12.13:1.
Also, you might want to try pulling the ABS fuse next time and see how it behaves.
d1ck is offline   Reply With Quote
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 88 08-26-2013 11:49 PM
Mysterious microscopic hole Aznek Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 07-09-2012 08:22 PM
A/C Shifts off when accelerating hard? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 29 06-19-2012 12:24 AM
How hard to replace BRZ Nav with aftermarket Nav? eikond Electronics | Audio | NAV | Infotainment 9 05-28-2012 07:52 PM
Casey Stoner high speed cornering at 1000fps tranzformer Off-Topic Lounge [WARNING: NO POLITICS] 6 08-01-2011 04:20 PM
