Old 04-14-2014, 11:43 PM   #1
qqzj
Drives: MDX, Camry
Do you warm up the car every morning b4 driving?
I now wait till the rpm drops to about 1000 b4 driving. After I start driving, I try very hard to keep the rpm below 2500 until the water temperature is normal. Then I drive with WOT. Making this so complicated just to be gentle to my engine. I have a manual BTW.
Question is whether this is good or bad or simply does not matter? Some people start with 3000/4000 will warm up the cat quickly which is good to cat. I am quite confused. Any good theory out there?
qqzj is offline   Reply With Quote
Old 04-15-2014, 12:06 AM   #2
phuthinhon
Drives: 13 BRZ
i always wait until the rpm drops to about 1k before I drive.
phuthinhon is offline   Reply With Quote
The Following User Says Thank You to phuthinhon For This Useful Post:
jimmillion (04-15-2014)
Old 04-15-2014, 12:11 AM   #3
dbrandt01
Drives: none
I start it and let it run til it drops in RPMs after 30 seconds or so, then just take it easy for a couple minutes going out of the subdivision because there is no reason to drive hard or fast through there. I've always done it this way even in my truck i used to have. Just habit I guess
dbrandt01 is offline   Reply With Quote
Old 04-15-2014, 12:43 AM   #4
SixthElement
Drives: 2013 black limited
I'm with dbrandt01. That's what i've always done. The biggest thing for the motor is to let the oil get to operating temp that way it is at the viscosity that the engine was designed to perform at before driving it hard.
SixthElement is offline   Reply With Quote
Old 04-15-2014, 12:56 AM   #5
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I wait till the rpms drop then I go. I keep things under 4000 rpm when the engine is not fully warmed up. Try to shift under 3500 mostly.
hmong337 is offline   Reply With Quote
Old 04-15-2014, 01:08 AM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://www.ft86club.com/forums/showthread.php?t=62756
Old 04-15-2014, 05:31 AM   #7
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
I usually wait for the idle to drop, then keep things under 3500 rpm until the water jacket gets up to its normal operating temp. It usually takes five or ten minutes for that to happen and for the transmission to start feeling warmed up.
I wish the car had an oil temp gauge.
Ganthrithor is offline   Reply With Quote
Old 04-15-2014, 05:44 AM   #8
housecat
Computer Scientist
housecat's Avatar
Drives: 2014 BRZ Limited
I put on no gas until revs drop. That is very important so oil gets through the system. When temp needle is below cold, I give some constant 2k to 3k rpm until temp needle is actually pointing not 'negative' ie "off the charts" to the left. Without doing this, my brz will not shift into 2nd gear if it is cold outside.
Keep calm and drive safe
housecat is offline   Reply With Quote
Old 04-15-2014, 09:46 AM   #9
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
No warm-up unless its below 0 Celsius, but I drive like a grandpa for the first 10+km no matter what to get all the fluids up to temp.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 04-15-2014, 10:59 AM   #10
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I don't let it warm up, but I don't drive it hard in the morning.
Also the car hardly ever sees anything below 50 degrees anyway.
Old 04-15-2014, 11:03 AM   #11
Turbowned
Turbowned's Avatar
What everyone else said, basically.
Old 04-15-2014, 11:07 AM   #12
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
When cold, I don't necessarily wait to get the car moving. I believe some load on the engine, even when cold, is better for the engine because it increase the (oil) pressure. However, I keep it under 25 MPH and moderate RPM in any gear until several clicks up on the H-2-O temp indicator.
I do not have a problem with entering second gear as some do.
BRZfan is offline   Reply With Quote
Old 04-15-2014, 11:18 AM   #13
Imrac
Drives: 13 SWP BRZ Prem
[ame="http://www.amazon.com/ELM327-Bluetooth-Diagnostic-Scanner-Scantool/dp/B0051CAE1C"]Amazon.com: ELM327 Bluetooth OBDII OBD2 Diagnostic Scanner Can ELM 327 Scantool Check Engine Light Car Code Reader: Electronics[/ame] + Torque App = Oil temp gauge.
I usually don't warm up before moving as I am in a garage and exhaust is rather loud at 4:30AM in the morning for my neighbors, I try to scoot out quickly. (while keeping under 3k RPM)
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 04-15-2014, 11:28 AM   #14
wheelhaus
wheelhaus's Avatar
I begin moving almost immediately, but drive gently below 3k until the needle is above C. Then drive normal under 4k until temp has stabilized. No redline or WOT until I've been driving 10-20 minutes depending on ambient temps.
0w20 full synthetic flows easily below freezing, but I believe idling/running at cold temps should be kept as short as possible. I want to get it warmed up as quickly as possible.
wheelhaus is offline   Reply With Quote
Warm air from vents blunova Issues | Warranty | Recalls / TSB 131 10-06-2020 01:27 PM
Warm Up? gt865 Scion FR-S / Toyota 86 GT86 General Forum 71 09-17-2014 11:28 AM
Ignition for Cat warm up Toyota John Software Tuning 8 04-16-2014 12:14 PM
How long do you warm up car before driving? djmm Scion FR-S / Toyota 86 GT86 General Forum 62 04-13-2014 02:34 AM
Warm up time white_knight Scion FR-S / Toyota 86 GT86 General Forum 47 03-14-2013 03:55 PM
