#603 | |
Drives: Satin Pearl White BRZ - Limited
Sent from my SM-G928T using Tapatalk |
| The Following User Says Thank You to BRZ_HaVoKx For This Useful Post: | solidONE (07-08-2016) |
#604 | |
Drives: Toyota 86 GTS
#605 | |
Drives: FT86
P0031 is primary 02 sensor heater circuit fail, coupled with no reading for afr I would say you have problem with primary 02 sensor wiring or connector. If the wiring is shorted melted then its likely blown the o2 sensor HTR fuse. are you running one of the new flex fuel SBD roms ? |
#606 |
Drives: FT86
#607 | |
Drives: FT86
If you have one of the flex tunes break out the hex editor and search for ZA1J in the hex code are all three calid the same ? or is one ZA1JA01G |
#608 |
Drives: GT86, 22 BRZ
I read the facelifted 2017 model has a much improved stability control system with a Track button instead of Sports that cuts in more gently and allows for more sideways action.
I wonder if the updated VSC program can be uploaded to the older cars via the OFT? |
#609 |
Generally when ROM logic is updated due to hardware changes, the roms aren't compatible on the mismatching hardware platform. Example: MY14/MY15 dash module update. That is unless you're particularly adventurous or you don't particularly care if all your hardware works as correctly. It would be nice if all newer roms were backwards compatible, but I think you'll find the MY17 will be the absolute most backwards incompatible.
#610 | |
Drives: FT86
Also the car has sevral different control modules, the oft only talks to the Engine control module ECM/ECU the VSC is a completely different module that the oft does not talk to. you may be able to load software with Techstream, but getting a copy of the vsc code is another problem. The other issue as wayne said is that not only must the software you load into each control module be suitable for that module (ie the 2017 may have different hardware in the VSC module), the computers/modules in the car all talk to each other, and the VSC module talks to the ECU to tell the ecu to say reduce throttle when you slide. So the software in each module needs to be compatible or the modules may not take the correct action when signaled by other modules in car. |
#611 |
Drives: UK GT86
Begs the question.... will a MY17 VSC module, dash and updated map on the current models work?
.: Stealth 86 :.
#612 | |
The Stig's German cousin
All the nannies off will always be faster, unless they put something in along the lines of what the GTR has...and that is big time $$$. So IMO you'll spend a lot of time and money in a retrofit, and still be slower than the guy who just turns it all off. Not worth it. Just learn how to drive. |
#613 |
Drives: '15 WRB Brz
I've been wanting to get an OFT, but as a 1st timer, kinda scared of taking the leap. I have a UEL header and a GrimmSpeed intake. 91 octane the most readily available fuel in my area.
I assume it's fairly easy to install with YouTube tutorials. What kinda tunes comes pre-programmed into the unit? Or can you pick and choose? And does the unit need to stay plugged into the car for the tunes to work? As for the CEL, will that need to manually be cleared each time you turn the car on?
Follow me on Instagram
https://instagram.com/anamishwoman/ '15 WRB BRZ Limited (Summer) '93 Ford Festiva L (Work Horse / Race Project) |
#614 | |
Drives: FT86
grimspeed intake should not need any tune adjustments one of the few that dont. cel is already disabled in the stage2 tunes for uel headers the oft flashes tune to ecu after that you dont need to have it plugged in unless you want to log or use guage functions. tune is permanent till you reflash a new tune or your stock tune back to ecu, removing battery connection does not alter tune just resets ecu. |
| The Following User Says Thank You to steve99 For This Useful Post: | An Amish Woman (07-20-2016) |
#615 |
Drives: '13 SSM BRZ Limited 6MT
Is it normal for the OFT stage 1 tune to run rich? Stock tune the ltft never goes past -5% ltft but after flashing the tune it goes to -9% on idle. Going back to stock tune will cap it at -5% ltft.
#616 | |
Drives: FT86
ltft % does not indicate its running rich, ltft is the amount of correction the ecu is applying to the fueling to attempt to hit the target afr. high ltft can be due to maf scaling error or change in intake causing maf scaling error, or large changes in intake air temps or ethanol percent in fuel. you need to compare afr commanded and afr (measured) to see if its running rich |
| The Following User Says Thank You to steve99 For This Useful Post: | tracerit (07-19-2016) |
| WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 07:13 PM |
| Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
| FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
| FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 02:49 PM |
| Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
