Old 07-07-2016, 09:16 AM   #589
BRZ_HaVoKx
BRZ_HaVoKx's Avatar
Drives: Satin Pearl White BRZ - Limited
Need some assistance please, my OFT is not reading my AFR after my first log I sent to shiv. I have played with all the pins and sockets to get a good connection and nothing has fixed it. Started car up this morning and it was reading for about 5 mins and stopped again. I need this working so I can get logs to Shiv, please input if you have advice thanks! Also getting p0031 code which I believe is for the primary sensor but not sure the cause...
Sent from my SM-G928T using Tapatalk
BRZ_HaVoKx is offline   Reply With Quote
Old 07-07-2016, 01:12 PM   #590
phrosty
Originally Posted by ValkenRebel View Post
I haven't noticed any real change in exhaust sound since I bought it (3500km on clock). I think it has to do with the ROM I've flashed as it seems to only happen at startup (when coolant temp below ~130 deg F). Once it's warmed up the ltft behaves itself.
Was thinking maybe there could be a heat expansion thing going on -- a leak that closes itself, but maybe not.
phrosty is offline   Reply With Quote
Old 07-07-2016, 02:16 PM   #591
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
If you are still under warranty, maybe bring to to the dealer to have it checked. Sound like you might have a faulty O2 sensor. Or if you are handy with a multimeter check the resistance and voltages you are getting to the heater wire and out of the signal wire. If it doesnt check out you'll have to replace yourself or try to get it warrantied.
Intent > Content
Old 07-08-2016, 09:06 AM   #592
ValkenRebel
Drives: 86 GT '16
Yeah, I see what you're saying. Any thoughts as to what might be expanding? I'm a bit of a noob, but could it be a head gasket, or more likely something else along the exhaust line (theoretically - if there was a leak)?
I'm heading out for some drifting on the wet pan (Eastern Creek - SMSP) this weekend, so I will be WOT/redline fairly often. Should I be worried?
Cheers
ValkenRebel is offline   Reply With Quote
Old 07-08-2016, 09:15 AM   #593
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I am curious about the new OFT friendly e85 flex fuel kit. Anyone using it? I searched for a thread and could not find one. Here is the LINK to the product.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following 2 Users Say Thank You to Takumi788 For This Useful Post:
AdrianSaldana (07-08-2016), Yoshoobaroo (07-08-2016)
Old 07-08-2016, 11:11 AM   #594
AdrianSaldana
That Guy
AdrianSaldana's Avatar
Drives: Fast and Hard
i was wondering the same, id like to run a ff kit as well
"Knowledge will give you power, but character respect.."
DD: 2007 Suzuki Sv650
Weekend Car: 1969 Chevelle
Summer/Weekend Car: 2014 BRZ
AdrianSaldana is offline   Reply With Quote
Old 07-08-2016, 11:14 AM   #595
steve99
Drives: FT86
check with the fftec or openflash guys.
Most flex kits put out 0 to 5v for ethanol content, suspect this kit will be same.
You also want to know if it comes with plug and play wiring and if the fuel line connections are "no cut" ie it just connects into existing fittings ie plug and play.
I suspect their using the OFT as the display.
It seem about same price as other kits from say moto-east or delicious if you factor in removal of display.
Old 07-08-2016, 01:11 PM   #596
Takumi788
JHerbert Racing
Takumi788's Avatar
I was talking about the fftec one. I should have clarified. I have not found any info on this kit. The openflash site says a custom tune is needed and I am ok with that. It looks like its a plug and play kit but I am weary with no other information than what is on the FFTEC site which just brags about the type of fuel hose it uses.
Old 07-08-2016, 03:31 PM   #597
BRZ_HaVoKx
BRZ_HaVoKx's Avatar
What do you have questions about? The kit has been covered in immense detail on the sbd turbo kit owners fbook page.
Old 07-08-2016, 04:04 PM   #598
steve99
Drives: FT86
Kit contents
is it all plug and play fuel connections and wiring connections
ethanol display ? or use oft only
maybe link to fitting instructions
rear 02 sensor or evap sensor connection option ?
what ecu rom calid are supported ? is it A01G only
Old 07-08-2016, 05:31 PM   #599
solidONE
solidONE's Avatar
Link? I've been waiting for this, but I havent seen the OFT guys posting any information on this.
Intent > Content
Old 07-08-2016, 05:40 PM   #600
BRZ_HaVoKx
BRZ_HaVoKx's Avatar
Kit contents
Plug and play fuel lines, yes. All pre fab'd XRP lines and fittings. Wiring requires one splice into the ecu at the cpc I believe I got out of Shiv about a month ago. Everything else is wired. Display is through the OFT only as he used a different content sensor then anyone else and he said the output is different for his application. Fitting instructions will be included when you receive the kit, which will be delivered sometime this weekend I love been told by Anthony at FFTEC they were waiting on a bulk fitting order to be delivered yesterday. There will be support for every CAL ID from what I've been told.
Any other questions or if I missed something just lemme know.
The Following 4 Users Say Thank You to BRZ_HaVoKx For This Useful Post:
DocWalt (07-08-2016), solidONE (07-08-2016), steve99 (07-08-2016), Takumi788 (07-08-2016)
Old 07-08-2016, 09:23 PM   #601
ShibaYuki
Drives: 2013 WRB Subaru BRZ Sport-tech
I haven't updated my OFT in a long time. Should I update and I was wondering if there's new updates to the UEL 91oct?
ShibaYuki is offline   Reply With Quote
Old 07-08-2016, 09:41 PM   #602
solidONE
solidONE's Avatar
Is the OFT flex fuel tune ready to go? Doesn't look like they've published anything for it.
Intent > Content
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
