Old 07-08-2016, 12:28 AM   #15
OP, it's fine. When engine braking at low RPM, feedback from the engine rattles the disengaged gears.
Same for the sound you hear when it's in neutral. Google "neutral rollover" and you'll feel much better. Welcome to the forum and enjoy your cool car.
edit: Sorry, @humfrz. My brother and I took the sports cars and ladies out to Point Reyes to see the lighthouse. Fun drive!
YIKES, ya'll didn't walk all the way down there did ya .......
Or did you read the sign and take a seat on the observation deck and attach a telephoto lens ......
OK, if you say so ....... "neutral rollover".
But why doesn't my car have a "neutral rollover" sound .......
Old 07-08-2016, 12:33 AM   #16
Originally Posted by weederr33 View Post
No, it doesnt. Just an added precaution honestly.
If you're using the clutch "properly" and it doesn't slip under maximum engine torque then expect it to live a long healthy life. Replace your TOB before it starts to seize and take out your pressure plate.
The stock clutch was specified according to the rated capacity of the transmission. It's supposed to let go before the transmission grenades under max torque.
humfrz (07-08-2016)
Old 07-08-2016, 12:38 AM   #17
Path down to the lighthouse was closed. We took a selfie with it in the background.
I don't know why you don't hear yours. I hear it from every single twin I've driven or ridden. It is very subtle. Like the guys here have observed, they only hear it with the radio and AC turned off.
Old 07-08-2016, 12:51 AM   #18
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Where do you go about getting a new TOB? I guess just the subaru parts store?
MS, CSCS, TSAC-F, CPT
Old 07-08-2016, 01:12 AM   #19
hmmmm........ maybe it has a frequency of some of mrs humfrz's conversation ....... and I just tune it out ........
Hey, have a nice vacation!
Ultramaroon (07-08-2016)
Old 07-08-2016, 01:19 AM   #20
I don't mean to hijack this thread, but I noticed a similar issue today.
When I press the clutch in, there is a strange rotating/ grinding noise. Same when I'm braking with my engine but at lower RPMs (<3,000). Again, it's very subtle, and only really noticeable when music/ A/C is off. I do have power mods, so I'm curious if it's my clutch slipping? Sorry for the noobness, I normally do plenty of research.
Another way to determine if your clutch is slipping is to set the emergency brake, put the car in 2nd gear, rev to about 2,000 rpms then let the clutch out slowly ........ if that kills the engine ....... your clutch still has life.
Where to get a TOB ? The dealer would be a good place.
Are you going to put it in yourself .. ??
Old 07-08-2016, 01:20 AM   #21
Yeah, or here's the rockauto listing.
http://www.rockauto.com/en/catalog/s...e+bearing,1968
I think the SKF unit is the OEM.
weederr33 (07-08-2016)
Old 07-08-2016, 09:38 AM   #22
weederr33
weederr33's Avatar
I don't have the tools to take my transmission out. So I'd have to take it somewhere.
Old 07-08-2016, 02:32 PM   #23
Good call.
humfrz (07-08-2016)
Old 07-08-2016, 04:14 PM   #24
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Been hearing all these noises since 30ishk, now at 75k. Nothing to worry about IMO.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
The Following User Says Thank You to Tt3Sheppard For This Useful Post:
zc06_kisstherain (04-11-2018)
Old 07-08-2016, 05:41 PM   #25
Why, all you need is a few cement blocks, a couple of 8' 4x4s and a socket set ......
jcw99 (07-08-2016)
Help!! Car Wont Start After Clutch Swap (25$ reward for solution!!) bren5279 Issues | Warranty | Recalls / TSB 44 07-03-2017 09:36 AM
Cruise control wont set after clutch install? ($$ reward for solution!) bren5279 Issues | Warranty | Recalls / TSB 18 12-05-2014 11:21 AM
Is there a clutch delay valve on BRZs? Chirping noises... torqueno Engine, Exhaust, Transmission 7 10-10-2014 01:48 PM
various noises abutterman Issues | Warranty | Recalls / TSB 0 10-23-2013 01:26 AM
I'll Just Leave This Here. Asterisked Accolade Off-Topic Lounge [WARNING: NO POLITICS] 11 06-11-2012 09:59 PM
