Old 12-04-2014, 12:00 PM   #1
bren5279
Drives: series.blurrr
Cruise control wont set after clutch install? ($$ reward for solution!)
SOLVED
So for some odd reason the cruise control will turn on, but wont set. This is after doing a clutch and lightweight flywheel install. All plugs are plugged in, but if theres one in particular that would cause this from some kind of position sensing then I can check again. Also, its a manual 2015
Symptoms:
- There is NO CEL!!! again NO Check Engine Light
- cruise control light lights up
- cruise control wont set and set light doesnt come on
-stock (no tune)
What Ive already Checked:
-No there is no CEL
-the car doesnt start in gear so the clutch switch should be fine(right?)
-The brake lights arent constantly on, so the brake switch should be ok(right?)
-The main cruise control light comes on so the fuse should be fine(right?)
Solution:
Took to subaru, Not sure what he did but something with the scanner or maybe something with the clutch switch…not 100% sure since he didn't have time to explain but its fixed so all good.
bren5279 is offline   Reply With Quote
Old 12-04-2014, 01:32 PM   #2
Kirby64
Drives: Galaxy Blue BRZ
Did you ever adjust the clutch pedal or mess with the clutch actuator? There's a push-button on the clutch pedal that turns off the cruise (and won't let it activate) if the clutch is pushed in even a little bit.
Turn on the gear indicator (http://www.ft86club.com/forums/showp...16&postcount=4) and see if it shows a gear (1-6, because reverse is ALWAYS displayed regardless of clutch pedal position) when the clutch is fully released.
If it doesn't show a gear besides reverse, you've got a problem with either A) the clutch actuator is messed up and you aren't releasing it all the way, or B) the switch is misaligned (potentially if you did the pedal adjustment incorrectly).
If it shows a gear, at least you can eliminate that button from the troubleshooting...
Kirby64 is offline   Reply With Quote
Old 12-04-2014, 05:58 PM   #3
bren5279
*** correction, nope gear indicator works fine
Old 12-04-2014, 07:11 PM   #4
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Check the two switches for the clutch pedal. They are both adjustable. The lower switch is for the ECU to detect if clutch is disengaged for cruise control and gear indicator, which sounds like your issue. The higher switch is for the ECU to detect if clutch is "fully depressed" as to start the ignition.
JDKane527 is offline   Reply With Quote
Old 12-04-2014, 08:49 PM   #5
bren5279
Ok I see both, the bottom one is completely pressed and the top one doesnt even touch when the clutch is released. And when pressed the bottom one doesnt touch at all and the top one is pressed in... seems right to me
Old 12-04-2014, 09:31 PM   #6
steve99
for some reason cruise is disabled if rear 02 sensor is removed/faulty.
If you have a tune often cel codes related to rear o2 are disabled so you might not get a cel, but rear 02 need to be connected for cruise to work i believe. does the cruise light come up yellow or green ??
Old 12-04-2014, 10:42 PM   #7
HapaHaole
Drives: Grocery cart
Make sure the neural position switch is good / plugged in.
SOLD: 2014 BRZ Limited WRB 6 Speed.
HapaHaole is offline   Reply With Quote
Old 12-04-2014, 10:44 PM   #8
bren5279
Wheres that? Didn't know manuals had it
Old 12-04-2014, 10:54 PM   #9
HapaHaole
yes the manual transmission has one, its on the passenger side middle top section on the rear case section of the transmission.
the wire harness is a few inches long, 2 wires.
Old 12-04-2014, 10:57 PM   #10
HapaHaole
here is a picture of it.
http://parts.cioccasubaru.com/showAs...sembly=6027666
check your reverse.. I think you might of swapped the 2 connectors.
Old 12-04-2014, 10:58 PM   #11
bren5279
Ohhhhh yeah yep its plugged in. I can check it with a volt meter though.
Old 12-04-2014, 11:01 PM   #12
HapaHaole
does the one next to it, reverse swapped by chance?
Old 12-04-2014, 11:30 PM   #13
bren5279
noope. Dont think you can swap those two as far as I know
Old 12-04-2014, 11:52 PM   #14
HapaHaole
At this point I would check the data stream and check for cruise control cancel codes, NOTE it does not turn on the CEL.
I am going to assume you drove it over 25MPH in gear and attempted to push the set button?
Help!! Car Wont Start After Clutch Swap (25$ reward for solution!!) bren5279 Issues | Warranty | Recalls / TSB 44 07-03-2017 08:36 AM
DIY : install cruise control system (CCS) aagun DIY (Do-It-Yourself) Guides 10 02-06-2016 11:23 AM
install cruise control coz for me roll connector / steering sensor fail aagun Issues | Warranty | Recalls / TSB 15 11-14-2013 09:29 AM
Cruise control notout86 Scion FR-S / Toyota 86 GT86 General Forum 50 05-13-2013 02:01 AM
