Old 11-27-2014, 10:40 AM   #1
bren5279
Drives: series.blurrr
Help!! Car Wont Start After Clutch Swap (25$ reward for solution!!)
*** SOLVED****
Out of all the cars Ive ever worked on Ive never been so stumped…. Just swapped a clutch in and now it won't start, yet it turns over just fine???
I officially have no ideas where to even begin… so Im offering 50$ to anyone who can lead me to the solution because I REALLY dont want to have it towed to a stealership.
2015 manual brz with prox key
Symptoms:
-wont start
-cranks perfectly fine
-key worked fine the night before
-no CEL
-all plugs plugged back in
-Doesnt even sputter or try to ignite…
What I did:
Swapped the clutch just exactly as the DIY says (including unplugging the battery), and changed the fluids with it.
Things Ive ruled out
-Battery is fine
-Starter turns it over fine
-Checked all fuses
-can hear fuel pump working
-rechecked all grounds
-has half tank of gas and started perfectly the night before
-(turns over, eliminating clutch switch, any jams, key, etc)
*** SOLUTION: Make sure the timing disk behind the flywheel does NOT rotate at all. Not 100% sure it was what caused it but after reinstalling everything and repositioning the disk it now starts.
bren5279 is offline   Reply With Quote
Old 11-27-2014, 10:47 AM   #2
Kevinn
Drives: 2014 BRZ Limited, Black, Manual
Did you forget to plug something back in? Check any harnesses.
Also see if there are any codes set
Kevinn is offline   Reply With Quote
Old 11-27-2014, 10:56 AM   #3
bren5279
No codes and there were only 2 plugs unplugged plus the battery, all are fine
Old 11-27-2014, 11:01 AM   #4
FirestormFRS
Sounds like the anti theft system to me.
FirestormFRS is offline   Reply With Quote
Old 11-27-2014, 11:09 AM   #5
Ozzman
Drives: old
You sure you didn't pinch any wires between the block and bellhousing?
Ozzman is offline   Reply With Quote
Old 11-27-2014, 11:23 AM   #6
bren5279
Absolutely positive.
Would the anti theft system allow it to still turn over?
Old 11-27-2014, 11:31 AM   #7
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
I tried starting mine with the two plugs on top of the transmission unplugged and it fired right up (just fyi).
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 11-27-2014, 11:35 AM   #8
Ozzman
Drives: old
Does the exhaust smell like raw fuel?
Old 11-27-2014, 11:39 AM   #9
Thorpedo
The SquadWhisperer
Watch this.
[ame="https://www.youtube.com/watch?v=4uwZpFu8Z10"]https://www.youtube.com/watch?v=4uwZpFu8Z10[/ame]
I know his wasnt turning over. But it might be worth a watch.
Old 11-27-2014, 11:40 AM   #10
bren5279
Nope doesn't smell like fuel at all, I HIGHLY doubt its flooded
Old 11-27-2014, 11:46 AM   #11
bren5279
Originally Posted by Thorpedo View Post
Watch this.
Yeah my key light goes green and it turns over fine so idk…?
Old 11-27-2014, 11:52 AM   #12
Ozzman
Drives: old
Do you have the ability to scan for codes?
Have you tried disconnecting the battery again?
Perhaps check the owners manual under antitheft.
Is there a crank position sensor that reads off the flywheel? Because if the ECU doesn't see the crank position signal it won't fire the injectors or the coils.
Old 11-27-2014, 12:01 PM   #13
bren5279
No but there also aren't any codes being thrown…
Yeah twice
Going to do that, but wouldn't that cause that to not turn over at all?
Yeah thats my main idea, however theres a sensing disk behind the flywheel that senses the position and its on the right way (as I can see from the opening at the bottom of the trans.
Awesome, dealership is closed. Upping it to 50$
Old 11-27-2014, 12:11 PM   #14
Ozzman
Drives: old
You sure you don't have that disk 180 out of phase or something like that? If you can pull the #1 coil put a plug in it and reconnect to the harness and watch if it fires, that can narrow down problems. If you get one spark, and one spark only the problem likely lies with the crank sensor or the tone wheel. My money is on the tone wheel not being installed correctly or damaged.
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 09:35 PM
filled up w e85 now car wont start..id1000s dw65s jdl kit kingkai23 Forced Induction 8 07-24-2014 10:56 AM
car wont start, winjet to blame?? 7M-King Cosmetic Modification (Interior/Exterior/Lighting) 21 12-29-2013 03:34 PM
Car Wont Start Up HELP !!*** ScionFR-S Issues | Warranty | Recalls / TSB 20 11-28-2013 01:01 AM
URGENT : CAR WONT START DarkCard Engine, Exhaust, Transmission 9 08-01-2013 08:57 PM
