Drives: None
CLUTCH NOISES WONT LEAVE ME ALONE :(
So, im starting to think I am cursed. My clutch is making some noises, and im about to light my car on fire for insurance money(only kidding).
First noise. When coasting downhill, my clutch makes this noise: [ame="https://www.youtube.com/watch?v=TvHOWQHfJG4"]Clutch noise? - YouTube[/ame] I have no idea what it is. And im about to lose it Next noise. When sitting at idle, in neutral, and the clutch in, I can hear a faint noise that sounds like something rotating. When I push the clutch in, the noise goes away. It is very faint, so you can only hear it with the A/C off, and the radio off. Sounds kinda like this video : I don't believe its the transmission, because it sounds further up? Any help that I can get would be amazing. Im trying to figure it out, but am lost Also, if its something that needs to be fixed, would it be covered under the Powertrain warranty?
How many miles on your car..??
Any power modifications..?? I'd guess it's the notorious throw out (release bearing). If so, some have gotten it replaced under warranty ..... some not. If that's the problem, the good news is that its not an expensive part; the bad news is that you have to take the transmission out to replace it. humfrz |
#3 | |
Drives: None
26000 miles. No mods other than the spring delete and clutch adjustment. I thought throwout bearings only make noise when the clutch is pushed in? The noises happen when its not pushed in |
#4 | |
True, that it is "working" only when the clutch pedal is depressed, however it can still make a racket when it is not working. Where is @Ultramaroon when we need him ....... he's got a good ear for these powertrain noises ..... ![]() humfrz |
#5 | |
Drives: None
Drives: None
[insert cool phrase here]
Drives: BRZ Premium
Take it in anyways. Make a fuss. Sometimes they might help you out. Just don't be rude to them.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I don't mean to hijack this thread, but I noticed a similar issue today.
When I press the clutch in, there is a strange rotating/ grinding noise. Same when I'm braking with my engine but at lower RPMs (<3,000). Again, it's very subtle, and only really noticeable when music/ A/C is off. I do have power mods, so I'm curious if it's my clutch slipping? Sorry for the noobness, I normally do plenty of research.
#10 | |
Drives: None
The throwout bearing should make most of the noise with the clutch pushed in
#11 |
not playing cards
OP, it's fine. When engine braking at low RPM, feedback from the engine rattles the disengaged gears.
Same for the sound you hear when it's in neutral. Google "neutral rollover" and you'll feel much better. Welcome to the forum and enjoy your cool car. edit: Sorry, @humfrz. My brother and I took the sports cars and ladies out to Point Reyes to see the lighthouse. Fun drive!
#12 |
Well it just started happening and just in time for the 50,000 mile mark lol. I'll be upgrading my clutch hopefully by the end of the year.
#13 | |
not playing cards
I've driven with some sketchy clutches. It's pretty easy to tell when they aren't quite up to the task.
#14 |
No, it doesnt. Just an added precaution honestly.
| Help!! Car Wont Start After Clutch Swap (25$ reward for solution!!) | bren5279 | Issues | Warranty | Recalls / TSB | 44 | 07-03-2017 08:36 AM |
| Cruise control wont set after clutch install? ($$ reward for solution!) | bren5279 | Issues | Warranty | Recalls / TSB | 18 | 12-05-2014 10:21 AM |
| Is there a clutch delay valve on BRZs? Chirping noises... | torqueno | Engine, Exhaust, Transmission | 7 | 10-10-2014 12:48 PM |
| various noises | abutterman | Issues | Warranty | Recalls / TSB | 0 | 10-23-2013 12:26 AM |
| I'll Just Leave This Here. | Asterisked Accolade | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 06-11-2012 08:59 PM |
