Old 06-28-2016, 07:09 PM   #43
NickDC88
NickDC88's Avatar
Don't change your oil right after you just drove it. I've never "torqued" my drain plug. It's common sense to know it can't be loose and you can't crank on it. I feel like this part is over simplifying an already simple task. It's convenient, yes, but it's also risky. See OP.
NickDC88 is offline   Reply With Quote
The Following 3 Users Say Thank You to NickDC88 For This Useful Post:
B-R-Z (06-28-2016), Luftwaffel (06-28-2016), Summerwolf (06-29-2016)
Old 06-29-2016, 04:12 AM   #44
DarkestBuddha
Drives: BRZ limited GBS
i have the short nipple version and it does not stick out of the skid plat.
it even says on the fumoto site not to get the normal nipple for cars with low clearance.
DarkestBuddha is offline   Reply With Quote
Old 06-29-2016, 08:03 AM   #45
ZZT86
ZZT86's Avatar
Drives: BR86
I have the short nipple FU and it comfortable clears inside the alloy plate but must always be careful. As others have suggested you will hit the front nose cone first before anything else
ZZT86 is offline   Reply With Quote
Old 06-29-2016, 04:06 PM   #46
lazyluka
Drives: GT86
Have had my Fumoto valve on since my first oil change (3+ years). No nipple version. Seems like it's well protected under the car.
No issues whatsoever and I took the car off road, on track. Damaged the front bumper once (off-road due to hitting a bump), no issues with the valve whatsoever. Still looks like new.
The valve will not "leak" oil, it's not that easy to open. If you hit something hard enough or hear a loud bang you should stop and check it out anyway. Regardless of what modifications you have it is just common sense.
lazyluka is offline   Reply With Quote
The Following User Says Thank You to lazyluka For This Useful Post:
stevesnj (06-30-2016)
Old 06-29-2016, 04:32 PM   #47
Originally Posted by Luftwaffel View Post
I think a no nipple version would be flush with the base of the oil pan, so I would probably run that, but then you lose the ability to attach a hose, which is the major draw of the Fumoto. I dunno.
I'm not disputing that many are running this with no issue, but I felt it would be remiss of me not to detail my own experience here. Your skid plate can and will flex given the right conditions. Your Fumoto doesn't flex with it. If you must have the nipple, run a shorty.
Actually, the shorty comes with a detachable nipple. I would use it if I hadn't lost it.
And yes, to call that bottom cover a skid plate is misleading. It's there just for aero. Not structural at all. Does look nice though and really helps keep everything clean underneath.
Old 06-29-2016, 04:37 PM   #48
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Go on a hard drive both with and without it, then come back and tell me it is not structural.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
funwheeldrive (02-24-2017)
Old 06-29-2016, 04:42 PM   #49
Never considered shear loading. Hmmm!...
Decay107 (06-29-2016)
Old 06-29-2016, 04:48 PM   #50
Decay107
Decay107's Avatar
Exactly, they'd have used plastic for a structurally insignificant part especially considering how much attention was paid to making the car light weight.
Old 06-29-2016, 04:57 PM   #51
Mmmm... I dunno about that. It gets super hot down there. Either way, it's a nice part. Not exactly a full blown skid plate but it's nice.
Old 06-29-2016, 05:05 PM   #52
Decay107
Decay107's Avatar
They'd have used thermal shield and plastic. I've seen it done on enough motorcycles to know that heat is a non issue on plastics with the proper insulation.
Ultramaroon (06-30-2016)
Old 06-30-2016, 12:31 AM   #53
Yeah, good point. That stuff is really effective. Hell, I dunno.
Old 06-30-2016, 01:56 AM   #54
ryoma
ryoma's Avatar
for what it's worth, there's this plastic piece on both sides of the header with thermal tape on the inside. it connects to the skid plate with the push lock buttons. it sits REALLY close to the header and when I installed my headers I was wondering if it would melt... but nope it is in perfectly fine condition. I guess thermal tape works wonders
Old 06-30-2016, 02:02 AM   #55
It really does. Decay107 has a special talent for getting me to question my understanding.
dammit
Old 06-30-2016, 10:03 AM   #56
stevesnj
stevesnj's Avatar
Originally Posted by jvincent View Post
I have the no-nipple version and it does not protrude below the skid plate. I can't remember exactly how much clearance there is, but IMHO it's more than enough.
If you hit the skid plate hard enough to deform it and then hit a no-nipple valve, chances are you were going to mess something up anyway.
I agree with this, I just installed mine few weeks back and there is plenty of clearance. Sounds like the car bounced enough to hit the valve on its way back down. Just one out of many failures seems to be driver error not product error.
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
FRSBRZGT86FAN (06-30-2016), lazyluka (06-30-2016)
FS: Fumoto Valve jvenetto Engine, Exhaust, Bolt-Ons 6 10-01-2015 07:16 AM
EZ oil drain same as Fumoto? wbradley CANADA 18 06-15-2015 03:40 PM
Fumoto valve in the winter? Muskokan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 02-25-2014 12:06 PM
Question about Fumoto valve Bleevin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 04-18-2013 09:27 AM
