Old 01-11-2014, 07:45 AM   #1
Muskokan
Drives: white Sport-tech
Fumoto valve in the winter?
Anybody use their Fumoto valve year round in the winter months?
I went to Napa today to get one ordered and the guy highly recommended i only use it in the summer, because as soon as some sand, salt, winter crap gets in there it never shuts all the way.
i never even thought about it but it makes sense, but i havent actually seen the valve so cant say by experience.
whatcha ya'll think?
Muskokan is offline   Reply With Quote
Old 01-11-2014, 09:35 AM   #2
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I've never had any issues.
I don't live in an area that uses salts and tons of sand though...
The way it's designed doesn't really look like stuff can get up inside of it anyway unless it's open.
Old 01-11-2014, 11:07 AM   #3
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Grease the valve like crazy, when it's time to dump, clean and repeat.
Rayme is offline   Reply With Quote
Old 01-11-2014, 11:14 AM   #4
z3ro
Wouldn't grease just make things stick worse? Think of how dusty your interior gets after using armorall.
I would assume you would want to clean it thoroughly then leave it.
z3ro is offline   Reply With Quote
Old 01-11-2014, 01:28 PM   #5
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Regardless of what you do, if you're scared of debris getting into it, just make sure you clean it before you drain it, use WD-40 or something similar that won't freeze. The grease would hold on to the debris yes, but also "stop" it from getting into the moving parts.
Old 01-11-2014, 02:58 PM   #6
DR 86
DR 86's Avatar
Two winters now in salty, icy Canada. Zero issues. I change my oil every 5000 so I should know if it was leaking etc.
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
DR 86 is offline   Reply With Quote
Old 01-11-2014, 04:29 PM   #7
Muskokan
Good to hear, do you clean it off at all or anything first? And do you scrape on deep snow a lot? Do you use the safety pin?
Thanks eh
Old 01-11-2014, 05:07 PM   #8
DR 86
DR 86's Avatar
No safety pin. Doesn't scrape. I'm lowered almost 2", my lip would scrape before the valve. Btw, I have the one without the nipple to attach a tube. And no, I don't clean it off, just open and drain then close.
Old 01-11-2014, 05:14 PM   #9
Muskokan
Thank you sir, exactly the reassurance I needed.
Old 01-11-2014, 10:01 PM   #10
reardrv
Drives: 2013 Subaru BRZ
You could just use the stock drain plug, I know it's not the cool thing to do but it works.
reardrv is offline   Reply With Quote
Old 01-12-2014, 10:20 AM   #11
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
CT winters for over 5 years. Never did a thing to maintain it, it just always works. Dont listen to auto-part cash register racers.
chulooz is offline   Reply With Quote
The Following User Says Thank You to chulooz For This Useful Post:
hmong337 (03-24-2015)
Old 01-12-2014, 11:30 AM   #12
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
It's a ball-valve, there's no issue with it sealing or not. Grime causing issues would make sense if it were one of those quick valves that have a bolt inside a bolt design since grime would get between the inner and outer pieces and the gaskets. But the Fumoto's ball-valve turns inside it's seal. There's no place for dirt to get in to cause it to leak.
I've used fumoto valves in the worst conditions and never had even a drop leak. Neither salt-belt winters nor competitive RallyCross have damaged one yet.
The Following 2 Users Say Thank You to Draco-REX For This Useful Post:
hmong337 (03-24-2015), MannyO (01-12-2014)
Old 01-14-2014, 03:04 AM   #13
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Remind your napa desk parts guy he's a parts guy not a well experienced mechanic lol. Fumoto valves are not allergic to anything ...
Old 01-22-2014, 11:56 PM   #14
reeves
I've had my fumoto valve through the last 2 winters with no problem.
reeves is offline   Reply With Quote
The Following User Says Thank You to reeves For This Useful Post:
Fumoto valve quick question #87 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 130 11-21-2015 04:32 AM
Fumoto valve for transmission? SurfAndSand Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 09-15-2013 11:01 PM
help me decide: Fumoto Valve or Greddy MagDrain chenshuo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 41 09-10-2013 09:43 PM
Question about Fumoto valve Bleevin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 04-18-2013 09:27 AM
FS: Fumoto quick valve Laika Engine, Exhaust, Bolt-Ons 1 01-08-2013 01:51 PM
