Old 06-16-2016, 11:41 AM   #15
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
17x9 + 35
If you're lowered & have some camber dialed in its perfect aesthetically.
Also as long as you don't get some super sticky rubber you can still break traction with relative ease.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
The Following 2 Users Say Thank You to Phantobe For This Useful Post:
Cole (06-17-2016), ysu (06-16-2016)
Old 06-16-2016, 05:40 PM   #16
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
Most competitive autocrossers go with 17x9 wheels wrapped in 245/40/17 Bridgestone RE71R. it give optimal traction for short bursts, but as temperature build up, it loses some grip properties, so it may not be the best for track. As for daily/weekend spirited driving, Michelin PSS are the most popular.
the most popular light weight wheels is Enkei RPF1(not my favorite design), but there are slightly more expensive alternatives such as Wedssport TC105N.
slyphen is offline   Reply With Quote
The Following User Says Thank You to slyphen For This Useful Post:
ysu (06-16-2016)
Old 06-16-2016, 08:32 PM   #17
ysu
Drives: Toyota 86 GTS Auto
Well, aesthetics is really secondary. I'd like to keep the car characteristics and not bog it down with a too big / heavy tyre. But I want a sticky tyre on the new rim. Track only.
I'll probably have to go with Enkei rpf1, it's Australia, and the alternatives are few and far between - and really expensive.
ysu is offline   Reply With Quote
Old 06-16-2016, 10:33 PM   #18
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I'm in the 17x8 +35 club. I like this size because it fits in the wheel wells perfectly with a bit of camber and a 1 inch drop and the rim width is great because you can run all the way from a stretched 215/45 up to a meaty 245/40.
My track setup is 17x8 +35 with 245/40r17:
Using old BFG Rivals this year but next year I'm thinking of going to a better compound in a 225 sized tire instead.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
ysu (06-17-2016)
Old 06-17-2016, 09:30 AM   #19
v1beeee
Drives: 14 FRS Whiteout
Originally Posted by D_Thissen View Post
17x8 +35 wheel and a 225/45R17 tire should be more than enough.
What tires are u running?
v1beeee is offline   Reply With Quote
Old 06-17-2016, 02:52 PM   #20
shattered_memory
Drives: Satin White BRZ Limited
Nice input I do have a question...what is your reasoning behind going to a 225 width tire from 245? Do you lose some feel with the wider tire?
shattered_memory is offline   Reply With Quote
Old 06-17-2016, 03:34 PM   #21
Cole
Not a troll
Cole's Avatar
Originally Posted by Mr.Impreza View Post
I'd stick to 215 personally, but if you track than i would go 225 max (personally)
235 will make steering heavy and take away the stock cars playful nature and turn it into a train.
My 17x9 245/40's disagree with handling like a train. I can still get loose and play. But that's just my anecdotal experience.
How many twins have you driven that aren't on stock tires?
Cole is offline   Reply With Quote
Old 06-17-2016, 03:36 PM   #22
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Do you feel bulgy with 245s? I know it comes down to the sidewall of the specific tire mfg as well. I was thinking of going up to 245 from 225 to pay my way up PAX
drewbot is offline   Reply With Quote
Old 06-17-2016, 03:44 PM   #23
D_Thissen
D_Thissen's Avatar
Pontenza RE760
Old 06-17-2016, 03:59 PM   #24
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Another one for 17x8 +35 w/ 225/45 tires for track day. The narrower 225 will give you better turn-in and response than a 235 or 245, and will still be plenty of tire for the power levels you can reach while keeping the car NA.
If you're doing autocross though 17x9 w/ 245/40 is the sweet spot. Dependent on class of course.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
Lynxis (06-17-2016)
Old 06-17-2016, 04:28 PM   #25
Lynxis
Lynxis's Avatar
Mostly cost related. I'm poor =(
Turn in and braking felt great to me but as you said, I think it depends on the relative stiffness of the sidewall. The old BFG Rival is known to have a very stiff sidewall so the 245 on an 8 inch wide rim felt great but something with a more flexible sidewall like the RS3 would probably feel better in 215 or 225 sized tire.
drewbot (06-17-2016)
Tire Width? wootwoot Tracking / Autocross / HPDE / Drifting 84 03-06-2019 07:44 AM
wheel width SlammedSilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-12-2016 04:15 PM
Track width -max- Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-21-2012 06:37 PM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
