Old 07-26-2012, 10:14 PM   #1
-max-
Drives: Firestorm FRS
Track width
Can someone tell me the track width front and rear. Need it to do an alignment.
-max- is offline   Reply With Quote
Old 07-27-2012, 07:07 AM   #2
d1ck
Drives: Black 2013 FRS
Should be in here:
d1ck is offline   Reply With Quote
Old 07-27-2012, 01:39 PM   #3
-max-
No, Not in there.
Old 07-27-2012, 02:27 PM   #4
fatoni
Measure it
Old 07-27-2012, 07:02 PM   #5
-max-
It comes down to mm. Has to be perfect. I am sure that the info is out there, just hard to do a search for FRS track width. All I get is about race tracks. Lol
Old 07-27-2012, 08:05 PM   #6
fatoni
if you really want that kind of accuracy, a number you get from the manufacturer isnt going to be accurate to that degree either
Old 07-27-2012, 08:06 PM   #7
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Subaru.com has it listed as does Scion.com.
I've adjusted track width to change handling before, but never during an alignment.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-27-2012, 08:16 PM   #8
-max-
Just need to know the difference between the front and rear really. My last 2 cars were 5 mm wider in the rear. Need to know this to use the string method.
Ill check there websites when I get off of work. Only have my phone right now.
Old 07-27-2012, 08:17 PM   #9
fatoni
i think hes planning on using string and chalk to align his car
Old 07-27-2012, 08:56 PM   #10
OrbitalEllipses
Drives: Attitude
Front track: 59.8
Rear track: 60.6
from http://www.cars101.com/subaru/brz/brz2013.html about halfway down the page.
VAcuban (09-10-2017)
Old 07-27-2012, 09:22 PM   #11
-max-
Thanks. I just found it on Subaru website also.
been burnt by crappy alignments too many times. If the rack is not calibrated right, your screwed. As long as you have a flat surface, its pretty damned simple to set toe and camber. For the price of a couple alignments, you can buy the stuff to do it, and know its right.
Old 07-28-2012, 09:42 PM   #12
d1ck
Care to share your setup?
Old 07-28-2012, 09:53 PM   #13
-max-
Alignment set-up?
2 jack stands, fishing line and a ruler for toe. Cheap, easy and accurate. Used this method on my last 3 cars
A digital level for camber. This might not be 100% accurate, but its repeatable. That is, 2.7* of camber might actually be 2.8*, but that sodas not really matter. What matters is how the tire is being used and being able to repeat the set up you want.
The Following User Says Thank You to -max- For This Useful Post:
Old 08-21-2012, 04:49 AM   #14
jlevy
Drives: 07 Mini Cooper S
I use the string method too
I've been setting toe by this method for 10 years now (WRX and Mini). It works well. I have a measuring device that resembles a long skinny triangle to give me the distances in mm (or tenths of a mm) between the string and tire. I have a digital camber measuring device as well, but rarely need to use it.
-JL
jlevy is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
Element Tuning Track Tested and Track Proven FRS Video Element Tuning Tracking / Autocross / HPDE / Drifting 47 07-17-2012 04:12 PM
$110 Track day at Willow Springs- Big Track -May5 in SoCal Louie Southern California 3 05-04-2012 01:05 AM
