Old 04-20-2016, 05:39 PM   #449
steve99
Drives: FT86
Originally Posted by Deagle50 View Post
"the checksum of file has been corrected"
WTH does that mean?
That's normal with oft tunes, it means oft has corrected the checksum of the rom. If you never saw that before then you were not uploading tunes correctly
Old 04-20-2016, 05:42 PM   #450
Deagle50
Drives: Ultramarine FRS, (MILA)
ive seen it before, figured it was normal but im just trynna pin point the problem now that im starting over.
kk i uploaded the e85 tune to tablet, now im gonna flash it and drive for about 15 min ill give you update in an hour or so maybe less. Thanks for all the help man
You da man!
Deagle50 is offline   Reply With Quote
Old 04-20-2016, 07:05 PM   #451
Deagle50
Originally Posted by new2subaru View Post
You should get some kind of award for all the information you post on here!
word
Old 04-20-2016, 07:12 PM   #452
Deagle50
Ok so i started from scratch and it looks a whole lot better now. Can u tell me if this looks stable though? may i still have an exhaust leak based on what you see? is my tune flashed correctly now?
http://www.datazap.me/u/deagle50/log...3?log=0&data=1
Old 04-20-2016, 07:34 PM   #453
steve99
Drives: FT86
Ok that's looking heaps better AFR is normal and ltft seems to be ok but its going to -100 off throttle and IAM alternates between 1 and 0. I think that's bogus and just a logging problem with OFT, they have a couple of issues at present with logging of some roms.
looking at KC Learned it appears knock is fine and IAM is not in fact 0
but it looks like your running an E85 tune now, even though logging of some parameters is a bit suspect.
You need to get onto the oft guys so they can sort out that logging as its difficult to read too much into it with the suspect parameters, but it looks safe from what I can see.
Old 04-20-2016, 08:19 PM   #454
Deagle50
I probably sound dumb but I'm not sure what to ask them haha
Old 04-20-2016, 08:31 PM   #455
HLHachiRoku
Drives: 2015 HL FR-S
Hey you got the FBKC -1024 too! haha ohh boy those OFH tunes are something. But i don't get why my reg ofs tune runs and logs fine, then these have those issues haha. hrmm.
HLHachiRoku is offline   Reply With Quote
Old 04-20-2016, 08:51 PM   #456
Deagle50
im not using the OFH tunes im using the off the shelf tune files
Old 04-20-2016, 09:09 PM   #457
HLHachiRoku
=O ohh my! now im worried to switch to E85... =(
Old 04-20-2016, 09:51 PM   #458
steve99
Drives: FT86
It not actually the tune itself (tune is ok) that the problem its the logging, the OFT is either asking for the wrong info from the ecu or scaling this info incorrectly. The oft has to be set to recognise each different rom calid and ask for correct info, looks like on some roms is asking for incorrect info from ecu.
email the oft guys and show them the problems in the logs
Old 04-21-2016, 01:16 AM   #459
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
Dam his knock corr is going pretty crazy. Is that normal on an E85 tune??
oldgunfan is offline   Reply With Quote
Old 04-21-2016, 06:33 AM   #460
steve99
Drives: FT86
correct i think the logging is bogus, the flkc does not match kc learned changes and other stuff is suspect, no it not normal
Old 04-21-2016, 07:01 AM   #461
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
You should generally ignore FBKC anyway.
Old 04-21-2016, 06:36 PM   #462
Deagle50
Ok i emailed them and i put the link to my log in email.
Hey dude quick question.
I just installed a front pipe on my car should i re-flash the tune after installing new performance parts?
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 04:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
