Old 07-20-2013, 05:55 PM   #1
elefunkd
Drives: brz
stock BR-Z, much detonation during shifts: tune?
I only have 2000km on my completely stock BR-Z. Since new, I noticed a brief moment of detonation while completing a gear-change.
This happens as the clutch is engaged and throttle re-applied, just as the engine is loaded again.
It happens when making quick gear-changes and semi-aggressive driving, while shifting just after the first torque peak, around 4k/rpm.
Do any/all of the available tunes address this issue? It is driving me nuts.
I now religously use sunoco 94 fuel which has not helped this issue.
Thanks!
-Thomas
elefunkd is offline   Reply With Quote
Old 07-20-2013, 06:53 PM   #2
suaveflooder
You, good sir, need to get into the dealer ASAP and get your direct injectors checked. Keep out of hight RPM and avoid shifting quickly. Don't mean to scare you, but it could be somewhat serious. You catch it before serious damage is done, you will be golden
suaveflooder is offline   Reply With Quote
Old 07-20-2013, 08:01 PM   #3
elefunkd
Drives: brz
Woah... sounds serious. I will make an appointment asap.
Has anyone else experienced something to that effect?
Old 07-20-2013, 08:32 PM   #4
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Search DI Failure and you will find plenty threads regarding this emergin issue :happy0180:
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 07-20-2013, 08:36 PM   #5
suaveflooder
Welcome to the forums! Crappy way to come in, but thankfully, you will find a lot of useful information
Old 07-20-2013, 10:46 PM   #6
Lonewolf
Lonewolf's Avatar
Drives: Moped
OP-
Not saying it's this issue, but it's worth informing yourself about what your symptoms could be:
http://www.ft86club.com/forums/showthread.php?t=36129
Old 07-21-2013, 03:01 AM   #7
ft_sjo
Drives: GT86
Thanks!
-Thomas
They all do it. The 'di failure' paranoia threads is dealt with by an updated calibration, however that won't resolve the 4k RPM tip-in det you're talking about. Most of the doom mongers won't know the difference though and will mislead you.
I wouldn't worry about it. Try not slipping the clutch during shifts.
Old 07-21-2013, 04:31 AM   #8
suaveflooder
Weird. My car doesn't detonate at high RPM's and shifting fast. I am hardly a "doom monger" as I don't drive the car enough in the manner needed to cause any sort of DI failure, so it is not a concern for me. But if the OP is truly getting detonation, that is NOT normal on any car.
Old 07-21-2013, 08:08 AM   #9
jamesm
Detonation is not a normal condition in any engine. Ever. Unless its a diesel.
Old 07-21-2013, 10:33 AM   #10
arghx7
Drives: car
How do you know it was knocking? Are you sure you're not just hearing driveline noise? Do you have ECUtek logs showing the knock?
I wouldn't say it's "desireable" condition, but it's certainly a normal one. Just about every modern engine runs on the edge of knock under certain conditions because that gives the best fuel economy. And knock isn't an all-or-nothing thing. There are degrees of severity.
arghx7 is offline   Reply With Quote
Old 07-21-2013, 11:39 AM   #11
elefunkd
Drives: brz
I am 100% certain it is detonation, and under the aforementioned conditions, it is quite pronounced and unmistakable.
As I would like to flash the ecu soon, my dilemma is such: should I take it to the dealer before flashing the ecu? Or try a flash that has a modified Transient Ignition Retard Table, IF there is such a flash available.
And aside from detonation at the aforementioned conditions, I haven't heard it happening any other time.
Old 07-21-2013, 12:12 PM   #12
elefunkd
Drives: brz
So to clarify: when driving the car very aggressively (up-shiftin @ or near rev limit, there is no audible detonation.
Only when accelerating moderately and shifting quickly just past the first torque peak.
Not exactly certain at what rpm, but I will make a mental note to check next time I drive,
but certainly nowhere near rev limit, nor at WOT.
If there is a tune that addresses this issue, I will skip the dealer visit and deal with it by flashing the ecu with said tune, as this is something I would like to do in the near future.
Thanks for the responses!
-t
Old 07-21-2013, 12:18 PM   #13
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
let the dealer check first..
it seems like its a DI issue and trust me you can blow your engine...
go to the dealer and tell them about it and ask them about the update ECU calibration
Old 07-21-2013, 12:18 PM   #14
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
a tune will prevent this issue for cars that never had an issue before, but if you already have the issue, it wont help as ur DI might be damage already
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
Visconti vs FA20Club vs Stock Tune Dyno Results mechaghost Engine, Exhaust, Transmission 153 07-08-2013 11:35 AM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
