Old 03-29-2016, 05:01 PM   #1
iPlayDrums
Drives: 2013 Scion FR-S - Raven - Auto
Auto FR-S - Oil Leak - Front Left of Engine
I have a 2013 Scion FR-S that's automatic and has about 33,000 miles on it. The only modifications to the car is a 2 inch Perrin Cat-back exhaust and a drop in K&N Air Filter. Recently I have started to smell burning oil from the cabin, so I looked around in the engine bay and discovered a bad oil leak coming from the front left of the engine. I have looked around and couldn't find any threads or posts about this and was wondering if anyone knew what it was coming from and what I should do? As in, can I fix it or will it need to go to the dealer? I'm still in the warranty period.
Here are some pictures of the leak:
iPlayDrums is offline   Reply With Quote
Old 03-29-2016, 05:12 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Front timing cover leak. Covered under warranty, will require engine pull.
-alex
Old 03-29-2016, 07:44 PM   #3
roddy
roddy's Avatar
Drives: '13 Ultramarine
For future reference, that's the right side...when specifying right or left sides of a car, it is always from the driver's (seated) perspective. Just an FYI...not being a smart ass.
Old 03-29-2016, 08:01 PM   #4
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
I'm not seeing this leak... am I just blind??...
Are you referring to that blackness on the block? It looks like undercoating/paint... If it leaked that much, I would assume it to be dripping.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 03-29-2016, 09:25 PM   #5
WELCOME to the forum @iPlayDrums ...........
Sure enough, it appears the cam chain cover is leaking.
As a DIY you may consider checking the torque on the cam cover bolts in that area.
Or, better yet, take it to the dealer for an evaluation and fix.
Old 03-29-2016, 09:32 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
You're kidding right?
Old 03-29-2016, 11:24 PM   #7
Maybe @DaJo is of the old school ...... it ain't a "leak", till it puddles up on the driveway .......
Old 04-04-2016, 10:36 AM   #8
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
This may not be the cam seal. I've seen a bunch of FRS/BRZ have issues with the dip stick area spewing oil from time to time.
The timing cover bolts are lower than where the leak/seeping is in your photo. So I'm leaning towards the dip stick issue theory.
Regardless, get it to a dealer and fixed.
- I had the dealer pull my motor and reseal my cam areas. They did a great job.
SpectreRT is offline   Reply With Quote
Old 07-15-2016, 10:21 PM   #9
kthxbai
kthxbai's Avatar
Drives: '13 Whiteout FR-S M/T
Attachment 134456
Attachment 134457
Attachment 134458
Attachment 134459
Did you ever find what was causing this? I noticed the same black gunk in the same spot on my engine last weekend after an oil change. Just crack 50k
Sent from my Nexus 6P using Tapatalk
kthxbai is offline   Reply With Quote
Old 07-16-2016, 12:26 AM   #10
Griever423
Drives: 2020 BRZ PP
Had the same issue with my BRZ. It was the dipstick O ring. Should be replaced under warranty. Mine was covered under powertrain warranty so you should still be good.
Griever423 is offline   Reply With Quote
Old 07-16-2016, 06:36 AM   #11
kthxbai
kthxbai's Avatar
Thank you for the info, will make an appointment with the stealership
Old 03-15-2018, 12:18 PM   #12
Mynismo08
Drives: 2013 Scion FR-S Firestorm Red
Bump AT Trans Leak
Was the dip stick the cause of the leak that you guys had or was it something else? I have about 70k miles on my FRS and the Automatic trans is starting to leak. I see a similar wet area, but it looks like the gasket for the trans oil pan may be failing. I didn't notice it until a buddy and I were installing a new front pipe to my car and the old one had a good amount of fluid burned on it. I am going to take a better look at it over the weekend so see what could be the overall cause of it.
Mynismo08 is offline   Reply With Quote
Old 03-16-2018, 11:48 PM   #13
Decep
Drives: 2013 FR-S Series 10
lol. maybe he works at the dealer.
i would take it to dealer and ask them to clean it, then pour UV dye in the crankcase, drive it for a few hundred miles and come back in and it should be visible.
automatic frs, oil leak, scion fr-s
oil leak, drivers side, front of engine carbonBLUE Issues | Warranty | Recalls / TSB 41 10-02-2015 11:51 PM
WTB: OEM Control Arms: Front Left & Back Left norcalpb Want-To-Buy Requests 0 02-26-2015 08:55 PM
Tranny fluid or engine oil leak? G.I.Choe Issues | Warranty | Recalls / TSB 1 05-28-2014 06:53 AM
Need front left oem wrb fender suboobaru Southern California 1 02-08-2014 11:38 PM
Small Oil Leak under center of engine? brillo Issues | Warranty | Recalls / TSB 6 11-09-2013 09:52 PM
