Old 03-13-2016, 03:41 AM   #15
Originally Posted by ft_86 View Post
Not quite sure when you say there's a hole for the cotter pin in the axle. The couple of YouTube videos that I saw just remove the nut and the discs stay on, of course with the wheel removed. Just ordered my axle nut for $20, $10 each. Bit overpriced if you ask me
My bad .... sorry, that was misleading .......
I was stuck, back in the day.......but, I see @Tcoat brought you into the 21st century .....
Old 03-13-2016, 03:48 AM   #16
Originally Posted by tracerit View Post
when replacing the axle nuts, how are you guys undoing the indentation? I placed a screwdriver there and hammered at it and it's not budging out :/
I don't believe anything "comes out". What you are wanting to do is move that part of that ring, that is scrunched down in the notch of the axle, up out of the notch, so the nut can spin off.
When replacing the nut, don't forget to push that part back into the slot so as the nut will not unscrew......
Old 03-13-2016, 04:20 AM   #17
tracerit
Drives: '13 SSM BRZ Limited 6MT
hi again humfrz!
oh, we're talking about the same thing, just worded differently haha. I'm trying to unnotch the notch so I can spin the current axle nut off. But I'm having trouble, method wise, on how to unnotch it. Maybe I'm too gentle, I'm able to access the nut with my aftermarket wheels so I'm probably not tapping it hard enough.
tracerit is offline   Reply With Quote
Old 03-13-2016, 04:35 AM   #18
hi again humfrz!
OK, I suggest you re-read post#9 from @BigFatFlip .
" -using a flat head screw driver (small enough to fit in the slot on the axle) and a rubber mallet, un-bend the staked axle nut by hammering it into the slot. The slot should be ramped so the more you push the screw driver in, the more it "wedges" up to it to un bend it."
Now, with that description and your picture, if you can't figure it out, come on back.
tracerit (03-13-2016)
Old 03-13-2016, 04:59 AM   #19
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
hi again humfrz!
You are basically trying to do this (see 0:20)
[ame="https://www.youtube.com/watch?v=7VCXSokDgPo"]How to make getting your CV axle nut off easier - YouTube[/ame]
Note that you don't have to get it completely "unnotched", just enough so you can start turning the nut with your breaker bar. It will straighten out some more as you spin it out. Don't worry about the screw driver in the disc, this is why you apply the e-brake.
The Following 4 Users Say Thank You to BigFatFlip For This Useful Post:
ft_86 (03-13-2016), humfrz (03-13-2016), Phantobe (03-14-2016), tracerit (03-13-2016)
Old 03-15-2016, 06:33 PM   #20
ft_86
Drives: 2013 Scion FRS
UPDATE
Just got my new axle nuts and tried installing them on the rear wheels. Taking them off was pretty simple just like it was mentioned, but re-staking them was a pain, probably because I didn't have the proper tools. Here's a pic to show how much I re-staked it. Can somebody tell me if this is enough or if I should've staked it more? After putting the lugs back in, it still made the noise that I recorded so I didn't bother putting it on the driver side. Made an appointment with the dealer tomorrow, hopefully whatever is the problem is, it is covered by the powertrain warranty so I don't have to pay anything.
ft_86 is offline   Reply With Quote
Old 03-15-2016, 06:46 PM   #21
BigFatFlip
BigFatFlip's Avatar
UPDATE
To me that doesn't look staked enough, I'd hit it with a punch a couple more times, basically you want the material to be in the slot to prevent any rotation.
I'd try the dealer anyway, I got both axles replaced under the power train warranty. The only reason I tried replacing the axle nuts myself was because the dealer wanted to charge me to diagnose the problem. Once they verified that it was axle failure, everything was covered.
Old 03-15-2016, 06:50 PM   #22
UPDATE
Looks like enough to me.
I wish you well at the dealership tomorrow.
ft_86 (03-15-2016)
Old 03-15-2016, 07:38 PM   #23
ft_86
Thanks for the info, really helps relieves the tension of spending hundreds of dollars on the axles. I'll mention that I tried replacing the axle nuts myself, hopefully they'll go straight to the axles.
Old 03-15-2016, 07:58 PM   #24
BigFatFlip
BigFatFlip's Avatar
I wouldn't go that far... I would just strongly encourage them to look at the axles, specially the CV joints.
Knowing the dealers I've worked with, they would take anything to deny a warranty claim, which doesn't make any sense because they make money on these. I had one dealer refuse to look at my issue because I had coil overs and "looked lowered" when in fact I was slightly higher than stock height. I had to drag the shop foreman with a tape measure to compare the ride height to a floor model to make my point. /rant
Best of luck
Old 03-15-2016, 08:25 PM   #25
Best of luck
Good point!
@ft_86 , it's OK to point to the rear axle, but, I wouldn't mention that you replaced the axle nuts. They may say that you didn't use "special tool" # xxxxxxx and claim you messed up the axle.
Let them go ahead and re-invent that wheel ..... nut ....if they wish.
Old 03-15-2016, 10:06 PM   #26
ft_86
Thanks for the advice guys, I'll make an update post tomorrow to see how it goes.
The Following User Says Thank You to ft_86 For This Useful Post:
humfrz (03-15-2016)
Old 03-16-2016, 03:12 AM   #27
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
CVs on these cars are notorious for going out, especially on lowered cars or cars that get beat on/drifted/tracked/autoXd.
Replaced both of my CVs at the dealer under warranty on my old FRS. Car was totally stock. First one was with only a couple AutoXs on the car. Second one was after some track days. Let the dealer check it out and they'll replace it.
- The Ancient BRZ Sacrament
by Zaku
Old 03-16-2016, 04:05 AM   #28
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
I had the exact same clicking noise on both driver and passenger side. You have to replace the axle nut and torque the nut more than you think you need.
I had a local shop install the axle nut but the noise still happened. I then took it to my performance shop they took everything apart and found they just needed to torque the nuts slightly further than spec to remove the clicking. Literally been click free for about a year now with very spirited driving.
The clicking for me happened near a complete stop, when I was engaging the throttle, pretty common problem for subaru axles. Retorque and have a performance shop do it lol
Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
OEM DRIVER SIDE REAR TOP HAT OMJM Want-To-Buy Requests 1 04-25-2016 02:33 PM
WTB: rear driver side fender liner take the cannoli Want-To-Buy Requests 0 05-13-2015 02:46 AM
LOUD TICK-TICK-TICK sound on right hand side PoRco Issues | Warranty | Recalls / TSB 16 07-28-2014 12:55 PM
Rear driver side clank and click spyingwind Issues | Warranty | Recalls / TSB 11 04-04-2014 11:26 PM
WTB: FRS rear driver side seat base. Raven604 Want-To-Buy Requests 0 09-05-2013 12:23 AM
