Drives: 2013 Scion FRS
Rear Driver's Side Tick
I posted another thread relating to this issue, and went to the dealer a couple days after, fearing that it could be my ball bearings or worst, my CV joints. First issue I had with my dealer was that they would charge me 150 just to take a look at my car and the guy that helped me out flat out told me that it probably wasn't gonna be covered by the warranty. So I left and took a look at my axle nuts, since it was reported that some nuts don't come fully torqued from factory. Went to autozone to rent a torque wrench and buy a 32mm socket to torque the nut properly, 140 lb/ft. After I did, my passenger rear wheel stopped making the clicking/clunk noise, but it was still present in my driver side rear. Here's a two videos showing the noise. First ones when I rock the wheel itself and the second is when I rock the front wheels, passenger and driver's side. Also here's a pic of the axle nut. Should mention that I have a set of wheel locks on all my wheels, after someone stole my stock ones. Thoughts on the problem?
[ame="https://www.youtube.com/watch?v=W3s25W5-QAY"]https://www.youtube.com/watch?v=W3s25W5-QAY[/ame] [ame="https://www.youtube.com/watch?v=TDrg10C0ekg"]https://www.youtube.com/watch?v=TDrg10C0ekg[/ame] |
Your vids are posted as "private".........
![]() If your car is still under warranty, I'd suggest you go to another dealer. humfrz |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
I've had a similar "tick", on both sides. If you do a search, I had a pretty involved thread documenting this "rear clicking".
First off, if you re-torqued the axle nuts with out undoing the crimp, you didn't do anything since those things are meant to keep them from rotating. Its usually suggested that you replace these instead, which I did, but did not fix my problem. Another common source was the e-brake, so have that looked at also. There were some folks who resolved this issue by having the tech re-lube or readjust their e-brakes. As humfrz mentioned, try working with another dealer. I spent a good deal of time getting bounced from one dealer to another due to my aftermarket suspension. Ultimately, I found a dealer who was able to warranty both axles, which turned out to be both broken(one inner joint failure, the other an outer). Best of luck |
Ohne Titel
Drives: 2017 BRZ PP ISM
@BigFatFlip - is there a dealer in the Bay Area that doesn't suck? Where did you go?
#5 | ||
#6 | |
#7 | |
#8 | |
http://www.ft86club.com/forums/showthread.php?t=95702 Although the last time I messed with an axle nut ..... the axle had a hole for a cotter pin ..... ...... I would venture to say, yes, undo the crimp, remove the nut, replace the nut, tighten and re-crimp.(if the wheel falls off ...... I was wrong ...... )humfrz |
#9 | |
Here's what I did: -put e-brake on -jack up rear of the car and put on jack stands (you will be cranking on this hard). Remove wheel -using a flat head screw driver (small enough to fit in the slot on the axle) and a rubber mallet, un-bend the staked axle nut by hammering it into the slot. The slot should be ramped so the more you push the screw driver in, the more it "wedges" up to it to un bend it. -Remove the axle nut. Make sure to use a breaker bar and not your torque wrench, you might also need to use an extension on the handle (piece of pipe or something) to get a longer lever arm. I had to use my jack's lever to bust mine loose. -Install new axle nut, make sure to add some anti-sieze just in case you have to do it again down the line. -Torque down to spec, then using a punch or a screw driver, re-stake the axle nut -sit back, revel in your accomplishment and have a beer Hope that helps! |
#10 |
Let's jump back to some basics here before arm chair diagnosing to deeply.
Mods to suspension? Mods to engine? Mods to wheels? If all stock then yes some of the previous info is probably it. If modded then a whole new set of possibilities appear.
#11 | |
#12 | |
Are you all stock?
#13 | |
#14 |
Drives: '13 SSM BRZ Limited 6MT
when replacing the axle nuts, how are you guys undoing the indentation? I placed a screwdriver there and hammered at it and it's not budging out :/
| OEM DRIVER SIDE REAR TOP HAT | OMJM | Want-To-Buy Requests | 1 | 04-25-2016 03:33 PM |
| WTB: rear driver side fender liner | take the cannoli | Want-To-Buy Requests | 0 | 05-13-2015 03:46 AM |
| LOUD TICK-TICK-TICK sound on right hand side | PoRco | Issues | Warranty | Recalls / TSB | 16 | 07-28-2014 01:55 PM |
| Rear driver side clank and click | spyingwind | Issues | Warranty | Recalls / TSB | 11 | 04-05-2014 12:26 AM |
| WTB: FRS rear driver side seat base. | Raven604 | Want-To-Buy Requests | 0 | 09-05-2013 01:23 AM |
