Old 03-01-2016, 01:04 PM   #631
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Originally Posted by WNDSRFR View Post
I took some measurements to compare to. Keep in mind that I have the original 1.5 dump batteries and the original starter battery. And my starter battery is getting weak. About every forth time I start the car, my radio turns off. I never turn it off so it should always be on when the car starts. but apparently it doesn't have enough power for both the starter and the radio, so the radio is sacrificed.
key on-engine off---Dump pack 27.02, Starter---13.0
key on-engine off-ESC engaged---less than 23.0
at idle---Dump pack 27.8, Starter---14.3
3000 RPM---Dump pack 28.0, Starter 14.4
The Phantom meter meanwhile stays at 28.3 the whole time except for when the ESC is engaged when it drops below 23.0.
It looks like your blower is just not drawing the proper amount of current for whatever reason. I would check all the connections again. And if you have an amp clamp....no never mind that would only work on AC.
Hmmm. I'm starting to think it is the Procede again. Rob's recommendation is to swap to the WOT switch and see. Need to review the wiring diagram again.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 03-01-2016, 01:20 PM   #632
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
If it's not battery I think it's procede. I would reload the map and run through the throttle mapping on it.
Installed Mods:
Old 03-01-2016, 05:09 PM   #633
stevo585
Drives: White 2014 BRZ
On a new topic has anyone set the activation point at 50% throttle (on a non-procede car of course).
I wonder what the boost level would do... might damage the compressor or stress it?
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 03-02-2016, 02:44 AM   #634
l0aded
Addicted
l0aded's Avatar
FIXED. kinda.
After I reflashed the Procede, twice, with Sojhinn's rev 2 map and re-calibrated the throttle which seemed to fix the issue. The first time I flashed it there was some weird stuttering going on so I had to double flash. After driving around for awhile I realized that my batteries DO have some issues as a second gear pull would drop my voltage down to the 17.Xs and shut off the ESC temporarily. I'm not sure if this is the root cause of the failure or if the calibration was thrown off somehow but either way it seems mostly fixed now.
I only had my ESC taken off completely for a day but it reminded me just how slow our cars without FI are <_<. It feels like there is literally no pull below 5000rpm.
I would like to thank everyone for the suggestions and Sojhinn for the amazing Procede map (I used rev2). The map seems to be much smoother than standard.
The Following 4 Users Say Thank You to l0aded For This Useful Post:
DAEMANO (03-02-2016), Sojhinn (03-02-2016), zc06_kisstherain (03-02-2016)
Old 03-02-2016, 10:44 AM   #635
Sojhinn
Sojhinn's Avatar
FIXED. kinda.
I only had my ESC taken off completely for a day but it reminded me just how slow our cars without FI <_<. It feels like there is literally no pull below 5000rpm.
Thanks bro. If you want a sportier map I have a rev 4 but it's not as smooth.
I have a few people driving with it.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
l0aded (03-02-2016)
Old 03-02-2016, 11:22 PM   #636
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
anyone know why the esc tunes aren't on open flash website anymore?
shaynek is offline   Reply With Quote
Old 03-02-2016, 11:22 PM   #637
Sojhinn
Sojhinn's Avatar
Just saw that yesterday... No idea.
Installed Mods:
Old 03-02-2016, 11:24 PM   #638
shaynek
shaynek's Avatar
It's been a while. plus we never get updated maps huh? lol
Old 03-02-2016, 11:25 PM   #639
Sojhinn
Sojhinn's Avatar
Kinda tapped in my opinion. Plus shiv no longer has the phantom installed on his ft86.
Installed Mods:
Old 03-02-2016, 11:27 PM   #640
shaynek
shaynek's Avatar
if you guys can talk him into doing a new tune i can alway lend my car to him
Old 03-02-2016, 11:29 PM   #641
Sojhinn
Sojhinn's Avatar
A member took his car to someone who tuned the phantom on the ecutek system. The person working on that tune is a very well respected member of this forum. He stated that shivs tune is pretty damn on point and you wouldn't get much more for a custom tune.
I'm not sure how much more meat is on the bone but you can always ask shiv for a custom tune.
In my opinion it wouldn't be worth it.
Installed Mods:
Old 03-03-2016, 02:30 AM   #642
shaynek
shaynek's Avatar
yea his e85 is prefect. no issues so far. on 91 kool managed to edit the tune so no more knocking. I will probably get one eventually once i settle down with an overpipe and a mid pipe
Old 03-03-2016, 02:07 PM   #643
stevo585
I had my MAF scaled for 1-3% fuel trims on my NA tune. When I installed the ESC they where 10% off again. Had to rescale that made a big difference is smoothness and throttle response. It will never be 100% right on e85 without flex fuel. The bucket trims don't do a very good job at hitting target AFR. Contrary to what Shiv says but depends on which tuner you want to believe.
Old 03-03-2016, 02:11 PM   #644
BRZ-y
Drives: Brz limited
hey guys,
I'm ESC v3, v1 dump pack, odyssey starter, e85, procede controller(sojhinn rev2 tune), oft (shiv esc e85 tune)
stock headers and overpipe.
Over the last couple of weeks I've noticed my volt meter climb from 28.3-5 up to a consistent 28.8 and sometimes 28.9
Should I be concerned? I know eventually I'll move up to the dual bigCranks, but what should I be looking out for?
BRZ-y is offline   Reply With Quote
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 09:08 AM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 07:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 04:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 10:51 AM
