Old 04-17-2014, 01:57 AM   #1
Shinigunz
Drives: brz
phantom supercharger restrictions?
Hello all when using an electric supercharger does it block the intake when its not running? i mean when the supercharger is not running is the car slower than the stock?
Shinigunz is offline   Reply With Quote
Old 04-17-2014, 02:37 AM   #2
DAEMANO
Time Traveller
Let me see if I can get this right.
The compressor turbine free-wheels until negative pressure is reached, then a feature called Drag-Reduction kicks in where the supercharger pulses the compressor to regain positive pressure. This actually adds about 5-10 hp even when not WOT and is a feature that can be felt while driving.
Old 04-17-2014, 02:58 AM   #3
Shinigunz
Drives: brz
thanks ,what is WOT? what kind of a total HP gain u get from the phantom?
Old 04-17-2014, 03:05 AM   #4
Shinigunz
Drives: brz
ive seen threads about blown motors, can this electric s/c cause the same problems?
Old 04-17-2014, 03:19 AM   #5
DAEMANO
Time Traveller
WOT is Wide Open Throttle.
Dynos with HP and Torque gains can be found on the first post in the Phantom Supercharger thread located here
http://www.ft86club.com/forums/showthread.php?t=39719
More info at the Phantom Supercharger Website
http://phantomsuperchargers.com
Old 04-17-2014, 03:22 AM   #6
DAEMANO
Time Traveller
Anyone who blows a motor with a Phantom ESC probably was being VERY careless. So I'd say chances are very low. As with any modification to your car, take plenty of time to learn in advance. Go slow, and enjoy the process.
Old 04-17-2014, 04:03 AM   #7
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
A blown engine could be caused by a number of things, this is true for NA or boosted. An engine under any boost increases the chances of going out due to increased stresses and fatigue. Typically in forced induction(FI) applications(super/turbocharger) engine failure it is due to either running too lean (too much air to fuel ratio), or over-boost. The former depends primarily on your tune. If at all possible, use a tune/tuner who has experience or a proven track record with the car/setup. That's not to say something couldn't fail, but a quality tune goes along way to protecting the engine. The second problem, of over boosting is not an issue with the phantom. The ESC is only able to produce about 4.5 psi max, and drops off to around 2 psi at higher rpms, where the engine is under the most stress. This is the lowest boost out of any F/I application, and translates to less stress on the engine over time. Also there are no wastegates or vacuum lines that can fail and cause the to boost to spike to dangerous levels.
It is relatively new, and only a handful have been testing for an extended period of time (longer than a year), this is a guess, but I believe there are about 40 to 50 running this setup, to my knowledge no one has blown their motor while running the Phantom.
Old 04-17-2014, 05:13 AM   #8
Shinigunz
Drives: brz
thank you guys, very informative
Old 04-17-2014, 08:54 AM   #9
Urmyson
If you compare this to any other FI kit, I would think it would be the safest due to having the least amount of boost. That and the fact that your only under boost when you hit WOT. The rest of the time you are driving your car in NA mode. With a normal FI unit your always pushing boost as the revs climb.
Urmyson is offline   Reply With Quote
The Following User Says Thank You to Urmyson For This Useful Post:
neutron256 (04-17-2014)
Old 04-20-2014, 09:49 PM   #10
stevo585
Drives: White 2014 BRZ
How about with the system turned off? DR would not be active and an intake restriction would exist at WOT, right? (not that you would ever turn it off lol) Just curious.
stevo585 is offline   Reply With Quote
Old 04-20-2014, 10:04 PM   #11
Boxer486
Drives: small
No, it has a drag reduction system that spins just enough even providing very very mild boost when not in use. The draw is minimal so there is practically no impact to the charging system and packs. It's all on the first page of one of these threads.
Boxer486 is offline   Reply With Quote
Old 05-13-2014, 12:50 AM   #12
GTO5005
Drives: White Scion FR-S
Best question would be how do you get one? Is rob the only vendor? If that's the case its going to be another month until he has more availible
GTO5005 is offline   Reply With Quote
Old 05-13-2014, 03:28 AM   #13
DAEMANO
Time Traveller
Yes @Robftss is the only vendor that I know of. It's his invention, project & product. Lots of details in the Phantom thread. also at his website http://phantomsuperchargers.com
@shiv@vishnu is also co-developing for application in Miatas.
Raven's WORKS Turbo Charged Daily Driver raven1231 Member's Car Journals 157 11-19-2015 06:46 AM
Phantom Charger Poll Gary in NJ Forced Induction 84 02-06-2015 02:18 AM
Phantom Superchargers VR46 User/Vendor/Sponsor Reviews, Feedback, Comments 5 05-22-2014 09:03 AM
Why no high rpm boost for Phantom ESC? stevo585 Forced Induction 11 02-11-2014 07:51 PM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
