Old 02-17-2016, 12:38 AM   #1
zypher10
zypher10's Avatar
Drives: GT86
Synchro issue
Hi guys,
I think i have a problem with my synchro, it grinds when shifting at high revs from 3rd to 4th gear.
Any one had this problem? I'm out of warranty, so what would the cost to get this fixed, going to the dealer ship to have it looked at, but want to know a price so they don't rip me off.
cheers
zypher10 is offline   Reply With Quote
Old 02-17-2016, 12:53 AM   #2
http://bfy.tw/4IgQ
dvasqu01 (02-17-2016)
Old 02-17-2016, 03:18 AM   #3
dvasqu01
dvasqu01's Avatar
Drives: Scion FRS Whiteout
Much help 😂😅
Yes I'll give you the rice noodle😘
dvasqu01 is offline   Reply With Quote
Old 02-17-2016, 09:20 AM   #4
bababooey
Drives: BRZ SWP Limited -6MT
yes, same issue. original tranny fluid. resolved issue by shifting sooner, or a little slower. will keep an eye out for the next 30k so miles or until I can find something better to go to the dealer for a check.
bababooey is offline   Reply With Quote
Old 02-17-2016, 12:11 PM   #5
Originally Posted by zypher10 View Post
Hi guys,
cheers
Hi zypher10 ......
First off, I would suggest you "check" your shifting technique.
(remember, a warmer transmission is a happier transmission)
I would suggest that when shifting, wind up the last gear pretty tight (4-5,000 rpms) before shifting into the next higher gear.
Also, when shifting, pull (or push) the shift lever slowly and firmly into the next gear.
I suggest you NOT "lazy leg" it ……. be sure to push the clutch pedal all the way to the floor.
Check and make sure the clutch/brake fluid reservoir is full.
Also, you may wish to check the clutch adjustment.
If this technique doesn't help, you may consider changing the brake fluid and bleeding the system.
Your transmission may like some new (different) oil.
Old 02-17-2016, 02:27 PM   #6
Originally Posted by dvasqu01 View Post
Much help ����
Yes I'll give you the rice noodle��
I know. I felt kind of d!ckish but it was my turn.
Old 02-17-2016, 11:52 PM   #7
Ozzman
Drives: old
Had the same issue occasionally, trans was replaced under warranty.
Ozzman is offline   Reply With Quote
Old 02-17-2016, 11:57 PM   #8
"D!ckish" does not become you, @Ultramaroon ........
We already have enough "experts" in that field on this forum ......
Old 02-18-2016, 12:17 AM   #9
But there are sooooooooo many threads on iffy synchros it's hard to believe OP searched at all.
You're right, though. I'm not that guy.
humfrz (02-18-2016)
Old 02-18-2016, 05:43 AM   #10
dvasqu01
dvasqu01's Avatar
When do I get my turn lol
Old 02-18-2016, 12:56 PM   #11
I don't recommend it. You don't strike me as a "Search, noob!" kind of guy either.
Like @humfrz said, let's leave that to the professionals.
humfrz (02-18-2016)
2nd gear synchro FIX- MT owners read this thread gmookher Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 477 01-06-2019 06:22 AM
Synchro issue? and Dealership woes. lextrueno Issues | Warranty | Recalls / TSB 31 05-28-2017 02:16 PM
Double Clutch vs Synchro wear Concorazon Engine, Exhaust, Transmission 72 12-10-2015 03:16 PM
5th gear synchro harshness? Subie Issues | Warranty | Recalls / TSB 28 05-29-2013 04:22 PM
Will FT-86 have Synchro Rev Match? Dark Scion FR-S / Toyota 86 GT86 General Forum 56 05-27-2010 11:05 AM
