Old 01-06-2013, 11:27 PM   #1
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
5th gear synchro harshness?
Is anyone else experiencing resistance from the 5th gear synchro, mainly when downshifting from 6th to 5th? I don't encounter any resistance downshifting to other gears, but 5th gear is a pain every time.
Subie is offline   Reply With Quote
The Following 2 Users Say Thank You to Subie For This Useful Post:
Mo707 (01-12-2013), supramkivtt2jz (05-30-2013)
Old 01-06-2013, 11:33 PM   #2
Le86
Drives: Asphalt FR-S
This happened to be the other day when I was getting on the freeway. Shifting from 4th to 5th, it didn't seem to go into gear all the way and grinded. Or maybe it was my fault since I was exhausted from work. Either way, I'm at ~3500 and plan on changing the gear oil soon.
10/01/2012 FR-S down for P0019 code. Received vehicle back from dealership with a new ECU 10/30/2012
Le86 is offline   Reply With Quote
Old 01-06-2013, 11:37 PM   #3
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
I have the same behavior. As long as it engages without too much "grittiness" you should be ok. I almost never do the 6-5 downshift, so no biggie. I think the lack of triple cones on the higher gears carries some logic. When I take my time and try to do a good rev match, it feels better.
tech4pdx is offline   Reply With Quote
Old 01-06-2013, 11:43 PM   #4
tech4pdx
Make love
tech4pdx's Avatar
I would guess that 5 and 6 are single cone.
Old 01-06-2013, 11:43 PM   #5
Subie
Señor Member
Subie's Avatar
My thoughts exactly (emphasis mine). I'm wondering if it would be better to downshift into 4th instead for synchro longevity since it comparatively engages with ease. I may change the transmission fluid soon to see if it changes the behavior at all.
Old 01-06-2013, 11:47 PM   #6
tech4pdx
Make love
tech4pdx's Avatar
I changed my fluid to Redline and it made no difference. Every manual transmission I have ever driven in the last 12 years (including the infamous T56) has "issues". Drive that shit hard and don't sweat it too much. I might try Pentosin just for giggles.
The Following 2 Users Say Thank You to tech4pdx For This Useful Post:
Rayme (01-09-2013), Subie (01-06-2013)
Old 01-09-2013, 03:37 AM   #7
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
5th to 6th has been struggled a lot for me for whatever reason.
I'm around 6700 miles and been meaning to change out the trans fluids, its been getting .. grittier as the miles tack on
Old 01-09-2013, 08:10 AM   #8
whtchocla7e
Drives: 2013 FR-S Hot Lava
Drive it normally within limits and enjoy yourself. If it breaks from normal use then that's what the warranty is for.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 01-09-2013, 09:26 AM   #9
gmookher
I'm the pentosin guy, never any harshness any gear
gmookher is offline   Reply With Quote
The Following User Says Thank You to gmookher For This Useful Post:
tech4pdx (01-09-2013)
Old 01-09-2013, 12:27 PM   #10
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
If it's triple cone vs single cone, then wouldn't the 4th have the same issue as 5th and 6th?
Mine shifts smoothly to any gear.
Sigh-on-Rice is offline   Reply With Quote
Old 01-09-2013, 04:11 PM   #11
tech4pdx
Make love
tech4pdx's Avatar
I am not 100% sure but I'm speculating that 4th is double cone. We know that these Aisin transmissions are stubborn when cold and we also know that out of the factory, some may be "out of spec". I have 2000 miles on mine and 4-5 upshift / 6-5 downshift are gritty. It doesn't inspire confidence. I'm rev matching but it doesn't feel right. I am definitely going to try the pentosin.
The Following User Says Thank You to tech4pdx For This Useful Post:
Sigh-on-Rice (01-09-2013)
Old 01-09-2013, 04:23 PM   #12
tech4pdx
Make love
tech4pdx's Avatar
Right on.. Thanks for testing.
Amir Ghadiri (08-11-2013)
Old 01-09-2013, 04:54 PM   #13
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
I noticed going from 5th to forth is a PITA, although it's probably cuz I keep hitting the gates when downshifting, thinking its like my Ranger haha still not used to actually sliding it down over than down, vs an almost diagonal movement with the truck(virtually no gates).....
Gords_zenith is offline   Reply With Quote
Old 01-09-2013, 05:35 PM   #14
OrbitalEllipses
Drives: Attitude
I find 5-6 to be much worse than 4-5.
2nd gear synchro FIX- MT owners read this thread gmookher Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 477 01-06-2019 06:22 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
Base FR-S Radio bluetooth synchro issueS! Duff_man Electronics | Audio | NAV | Infotainment 3 08-05-2012 04:36 AM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
Will FT-86 have Synchro Rev Match? Dark Scion FR-S / Toyota 86 GT86 General Forum 56 05-27-2010 11:05 AM
