Old 12-08-2015, 06:08 PM   #1
Concorazon
Concorazon's Avatar
Drives: 2016 Scion FR-S
Double Clutch vs Synchro wear
Would double clutching effectively reduce wear and tear on synchro?
Sent from my Nexus 5X using Tapatalk
Concorazon is offline   Reply With Quote
Old 12-08-2015, 06:49 PM   #2
swarb
Yes. But chances are the times you mess up trying to double clutch, would probably be worse than shifting regularly.
Let me guess... it is your first manual transmission car?
The Following User Says Thank You to swarb For This Useful Post:
Concorazon (12-08-2015)
Old 12-08-2015, 06:51 PM   #3
Concorazon
Concorazon's Avatar
Yes but I've been driving for a bit def not used to the new tech though
Old 12-08-2015, 06:57 PM   #4
New tech?
Cole (12-09-2015), stevesnj (12-09-2015)
Old 12-08-2015, 06:58 PM   #5
JoeC
Drives: Subaru BRZ Limited
are you referring to synchros as new tech?
JoeC is offline   Reply With Quote
The Following User Says Thank You to JoeC For This Useful Post:
Cole (12-09-2015)
Old 12-08-2015, 06:58 PM   #6
Concorazon
Concorazon's Avatar
I'm used to driving beat up trucks not an FRS so yea its a bit of a shock
Old 12-08-2015, 07:05 PM   #7
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
just make sure you're not granny shifting, not double-clutching like you should
The Following 15 Users Say Thank You to continuecrushing For This Useful Post:
Apoc (12-08-2015), El Guapo (12-09-2015), fika84 (12-08-2015), GhostRai (12-09-2015), Griever423 (12-10-2015), MisterSheep (12-09-2015), Muaddib (12-08-2015), pushrod (12-08-2015), soulreapersteve (12-08-2015), STV3 (12-09-2015), Tcoat (12-08-2015), tigermack (12-08-2015), Turdinator (12-10-2015), WhiteFRS69 (12-08-2015), WingZer0 (12-09-2015)
Old 12-08-2015, 07:06 PM   #8
Concorazon
Concorazon's Avatar
Lol Alright Vin
The Following 4 Users Say Thank You to Concorazon For This Useful Post:
continuecrushing (12-08-2015), soulreapersteve (12-08-2015), Tcoat (12-08-2015), tigermack (12-08-2015)
Old 12-08-2015, 07:27 PM   #9
humfrz
Here we go again .......
I just wished that the new, MT drivers, would quit listening to their drunk uncles, about how to shift a MT on modern cars……
On modern transmissions, I would say that double clutching will not significantly reduce wear and tear on the synchronizers, not in your average car’s lifetime.
Yes, if your vehicle was old and/or had 18 wheels, yes, double clutching would be beneficial.
Simplify your life …. just shift the damn car.......
humfrz
The Following 11 Users Say Thank You to humfrz For This Useful Post:
clayrush (12-08-2015), Concorazon (12-08-2015), Griever423 (12-10-2015), kch (12-09-2015), sgtcarrot (12-08-2015), soulreapersteve (12-08-2015), stevesnj (12-09-2015), Summerwolf (12-09-2015), Tcoat (12-08-2015), Toyarzee (12-09-2015), wireman957 (12-09-2015)
Old 12-08-2015, 08:05 PM   #10
Concorazon
Concorazon's Avatar
humfrz
Nothing wrong with asking but thanks for the input.
Old 12-08-2015, 08:13 PM   #11
D_Thissen
D_Thissen's Avatar
Damn... You beat me to it. OP I know where you're coming from but with modern transmissions I wouldn't worry about double clutching. Hell, when you get really good, you can no clutch shift
The Following 2 Users Say Thank You to D_Thissen For This Useful Post:
Cole (12-09-2015), Packofcrows (12-08-2015)
Old 12-08-2015, 08:20 PM   #12
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
clutch less shifting ftw
Packofcrows is offline   Reply With Quote
Old 12-08-2015, 08:31 PM   #13
Contrary to popular opinion on here these cars are not fragile little flowers.
Drive it and don't worry about whether it will last 10 years or 10 years and 4 hours.
axelo (12-09-2015), Concorazon (12-08-2015), strat61caster (12-08-2015), Ultramaroon (12-09-2015)
Old 12-08-2015, 08:38 PM   #14
strat61caster
strat61caster's Avatar
Experiment, do whatever makes the car happy.
I double clutch many of my downshifts on the street now (didn't during the first ~2 years of ownership), under 3k rpm but not when I'm at the track blipping the throttle to 7k. Seems backwards innit? But every car is different.
I've ground gears, forced the lever into place and put it in the wrong gear, but never done any damage. 43k miles and I think it operates better than it did on day 1. It's not a delicate flower as long as you're at least trying to operate properly.
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
axelo (12-09-2015), Cole (12-09-2015), Tcoat (12-08-2015), Ultramaroon (12-09-2015)
Clutch wear on BRZ kingstonalex BRZ First-Gen (2012+) — General Topics 15 09-04-2015 03:42 PM
Possible clutch wear? Romanov Engine, Exhaust, Transmission 6 06-11-2015 09:12 PM
Clutch wear and pedal adjustment mike the snake Engine, Exhaust, Transmission 4 10-29-2014 03:30 AM
Clutch wear? Pakjk89 Engine, Exhaust, Transmission 102 04-12-2012 07:21 PM
Will FT-86 have Synchro Rev Match? Dark Scion FR-S / Toyota 86 GT86 General Forum 56 05-27-2010 11:05 AM
