Drives: Black Scion FR-S
Water insulation
Hello everyone, I just recently install a reverse camera in my frs, and I ran into a bit of a problem. The wires don't fit in the rubber insulator that holds the wires to the trunk, so I routed the wires beside it. Now the rubber insulator doesn't fit back into the hole, and I'm scared water is going to see people inside. I've been thinking about shoving it back into the hole, taping it, and spraying plasti dip on it to keep the water out. Any suggestion on how to do it better?
#2 |
I would just use some tube silicon to seal it all up.
| The Following User Says Thank You to Tcoat For This Useful Post: | FRSBRZGT86FAN (02-17-2016) |
#3 |
Drives: 15FRS, 05MustangGT, 85Toyota truck
It's in a tube
#4 | |
3m Window weld or Permatex Marine Silicone Adhesive works really well for this kind of application as well
#5 |
| The Following User Says Thank You to Tcoat For This Useful Post: | ToySub1946 (02-17-2016) |
#6 |
I'm watching the news at the moment. Attempting to multitask.
And now that I think of it. Bodyshops/Painters don't like us to use Silicone...they'd rather we use Urethane. Maybe a painter could chime in and explain the details ? I do know that windshields are attached with Urethane. For some reason Silicone interferes with new paint application. Not sure if Silicone also may also promote rust on bare metal ?? Edit: For Tcoat...I'm way older than you, also don't even work since 2007. And the outside temp, earlier today 71 degrees F, now 48 degrees F. It's rough here in Cali. And I've still gotta cook tonight on the grille outdoors. Retirement is so difficult ! Last edited by ToySub1946; 02-17-2016 at 09:53 PM. |
#7 | |
I am building a model helicopter, watching TV (Big Bang), petting the cat on my lap and talking to my wife.
#8 |
Drives: 2013 Asphalt FRS
That is some really good stuff....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#9 |
Is it difficult to remove if I were to decide to do so?
#10 |
Drives: '15 BRZ ISM
First, are you sure the wires won't fit in the rubber pass-through tube? In my installation, it was tricky to get through, but I managed to shove them through by feeding a wire clothes hanger through that had a shoelace taped to the end, and in turn taping the wire to the shoelace. Did that twice for two wires, and then again to route it through some body panels.
I'd give that a shot before hacking together a solution that might make it much more difficult to work with in the future. |
| The Following User Says Thank You to Lelantas For This Useful Post: | kch (02-17-2016) |
#11 |
Yes, I've tried. The tube as too narrow for the bnc to fit in.
#12 |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | FRSBRZGT86FAN (02-17-2016), GhostRai (02-19-2016) |
#13 |
No. Just get a sharp blade and trim it out. Easy
#14 |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| Limited more sound insulation than Premium? | KNS | BRZ First-Gen (2012+) — General Topics | 10 | 01-27-2015 06:13 PM |
| Bonded Logic Sound Insulation - anyone tried it? | robwbright | Electronics | Audio | NAV | Infotainment | 4 | 06-10-2014 11:55 AM |
| Wheel well insulation | PNW FRS | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-06-2012 08:16 AM |
| Sound Insulation | developer | Electronics | Audio | NAV | Infotainment | 8 | 10-23-2012 10:27 AM |
| Car insulation | triwoody | Electronics | Audio | NAV | Infotainment | 18 | 05-26-2012 02:14 PM |
