Old 02-17-2016, 09:23 PM   #1
huynh_FRanciS
Drives: Black Scion FR-S
Water insulation
Hello everyone, I just recently install a reverse camera in my frs, and I ran into a bit of a problem. The wires don't fit in the rubber insulator that holds the wires to the trunk, so I routed the wires beside it. Now the rubber insulator doesn't fit back into the hole, and I'm scared water is going to see people inside. I've been thinking about shoving it back into the hole, taping it, and spraying plasti dip on it to keep the water out. Any suggestion on how to do it better?
huynh_FRanciS is offline   Reply With Quote
Old 02-17-2016, 09:30 PM   #2
I would just use some tube silicon to seal it all up.
FRSBRZGT86FAN (02-17-2016)
Old 02-17-2016, 09:31 PM   #3
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
It's in a tube
ToySub1946 is offline   Reply With Quote
Old 02-17-2016, 09:31 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
3m Window weld or Permatex Marine Silicone Adhesive works really well for this kind of application as well
Old 02-17-2016, 09:32 PM   #5
Originally Posted by ToySub1946 View Post
It's in a tube
Ha Ha I beat you!
ToySub1946 (02-17-2016)
Old 02-17-2016, 09:35 PM   #6
ToySub1946
ToySub1946's Avatar
I'm watching the news at the moment. Attempting to multitask.
And now that I think of it. Bodyshops/Painters don't like us to use Silicone...they'd rather we use Urethane. Maybe a painter could chime in and explain the details ? I do know that windshields are attached with Urethane. For some reason Silicone interferes with new paint application. Not sure if Silicone also may also promote rust on bare metal ??
Edit: For Tcoat...I'm way older than you, also don't even work since 2007. And the outside temp, earlier today 71 degrees F, now 48 degrees F. It's rough here in Cali. And I've still gotta cook tonight on the grille outdoors. Retirement is so difficult !
Old 02-17-2016, 09:39 PM   #7
Excuses excuses.
I am building a model helicopter, watching TV (Big Bang), petting the cat on my lap and talking to my wife.
Old 02-17-2016, 10:14 PM   #8
FRS Justin
Drives: 2013 Asphalt FRS
That is some really good stuff....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 02-17-2016, 11:08 PM   #9
huynh_FRanciS
Is it difficult to remove if I were to decide to do so?
Old 02-17-2016, 11:27 PM   #10
Lelantas
Lelantas's Avatar
Drives: '15 BRZ ISM
First, are you sure the wires won't fit in the rubber pass-through tube? In my installation, it was tricky to get through, but I managed to shove them through by feeding a wire clothes hanger through that had a shoelace taped to the end, and in turn taping the wire to the shoelace. Did that twice for two wires, and then again to route it through some body panels.
I'd give that a shot before hacking together a solution that might make it much more difficult to work with in the future.
Lelantas is offline   Reply With Quote
The Following User Says Thank You to Lelantas For This Useful Post:
kch (02-17-2016)
Old 02-17-2016, 11:34 PM   #11
huynh_FRanciS
Yes, I've tried. The tube as too narrow for the bnc to fit in.
Old 02-17-2016, 11:35 PM   #12
But...but... will that withstand 221 WHP ...... ??
FRSBRZGT86FAN (02-17-2016), GhostRai (02-19-2016)
Old 02-18-2016, 05:48 AM   #13
No. Just get a sharp blade and trim it out. Easy
Old 02-18-2016, 09:23 AM   #14
stevesnj
stevesnj's Avatar
http://www.homedepot.com/p/Gardner-B...-110/100212441
My 2016 Build thread
Limited more sound insulation than Premium? KNS BRZ First-Gen (2012+) — General Topics 10 01-27-2015 06:13 PM
Bonded Logic Sound Insulation - anyone tried it? robwbright Electronics | Audio | NAV | Infotainment 4 06-10-2014 11:55 AM
Wheel well insulation PNW FRS Scion FR-S / Toyota 86 GT86 General Forum 9 11-06-2012 08:16 AM
Sound Insulation developer Electronics | Audio | NAV | Infotainment 8 10-23-2012 10:27 AM
Car insulation triwoody Electronics | Audio | NAV | Infotainment 18 05-26-2012 02:14 PM
