Drives: asphalt frs
Car insulation
Hey guys,
I think this thread belongs here. Anyway I'm planning on installing some car insulation in the fr-s. My question is where are the main areas that I should focus on when installing the insulation. I'm mainly concerned about minimizing road noise. Thanks |
Drives: 2013 CBS BRZ-L 6AT
I've been considering this, too. Step one is definitely removing or disabling the resonator tube, but I have zero relevant experience or knowledge beyond that. I found some decent, basic information on the Dynamat site, though: www.dynamat.com
It looks like the order in which to insulate areas depends on what you're after (road noise dampening vs. audio system performance). The biggest road noise culprit seems to be the doors. Just for a ballpark comparison, check out their installation guide for a 1990-2005 MX5: http://www.dynamat.com/download/vss/...azda_Miata.pdf Again, I know zero about this topic, so this info is just what I was able to find via a basic Google search. |
Klaatu barada nikto
Drives: Raven FR-S MT
I used to be a huge fan of Dynamat for it's performance, but hated that it was so heavy. Adding 100+ lbs of sound deadening is painful on the performance. I just couldn't do it on my RX-7. I used Cascade for the RX and loved it. It's half the weight, and works as good, or better, than Dynamat. I did it just around the speakers in the RX, but did the doors and trunk in my Camry (I didn't care if I added weight to the Camry)
I am adding Focal Utopia Be speakers to my FR-S and will be using Cascade again around the speaker only. I'm justifying the extra 10-15 lbs or so by adding a Siebon CF hood to compensate (do no harm) http://cascadeaudio.com/car_noise_co...ntrol_kits.htm http://cascadeaudio.com/car_noise_co...B-2HD_Tech.pdf
I vow to do no harm. 2013 Raven FR-S Manual "Lenore" 1985 Silver RX-7 GSL-SE (Gone and missed) Last edited by Slartibartfast; 04-09-2012 at 01:00 PM. Reason: Tech sheet with wieght |
| The Following User Says Thank You to Slartibartfast For This Useful Post: | SR5 (04-28-2015) |
Site Moderator
Drives: Stuff
Do some research on DIYMA and similar sites. To really make an impact you need a combination of CLD tiles, MLV, decouplers (CCF for example), etc.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
Drives: Attitude
Yoga mats, seriously.
#7 | |
Resident HoneyBadger
Drives: Toyota Tacoma TRD Off-Road
That is all.
![]() Walk like a King, Be like a Sir, Swag it out like a Boss |
That Guy
Drives: 2013 asphalt FRS MT
sounddeadenershowdown.com
Site Moderator
Drives: Stuff
Unless you go prepreg carbon you'll be adding weight from sound deadening and most likely from the hood too.. at least the hood will more or less break even. The Aluminum hood is light and cheap CF is not (by comparison to real CF (aka pre preg)).
-Dave
#10 |
Site Moderator
Drives: Stuff
-Dave
#11 | |
Klaatu barada nikto
S2kphile... your signature is hypnotic.
I vow to do no harm. 2013 Raven FR-S Manual "Lenore" 1985 Silver RX-7 GSL-SE (Gone and missed) |
#12 | |
Site Moderator
Drives: Stuff
-Dave
#13 |
Drives: Beater
just crank up the BeSpoke
#14 |
Drives: 2008 Honda Fit Vivid Blue Pearl
On my 08 Fit I used hardwood floor acoustic underlay. Cut it to shape and attach it with 3M spray adhesive. It's no dynamat but it's light and cheap and works pretty well. As far as I can tell. I lost the resinator and put the stuff on the inside of the doors and in the spare tire well.
