Old 08-10-2015, 09:51 PM   #155
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by Astroboy View Post
Would a tune be required if I were to install the M E flex fuel kit....? I've already installed a turbo and already had it dyno tuned, but I don't want to have to install it and get it tuned right a way...I want to install it, and then get it re tuned once I have the time
Sent from my LG-D850 using Tapatalk
Yes you will need a tune. If you have an unlocked tune the functionality could be easily added in. If not then you'll want to ask your tuner to turn all that stuff on if they were using EcuTek.
Xero-Limit is offline
The Following User Says Thank You to Xero-Limit For This Useful Post:
Astroboy (08-10-2015)
Old 08-10-2015, 11:27 PM   #156
Astroboy
Astroboy's Avatar
Drives: None
Yes they used ecutek. Thanks
Astroboy is offline
Old 09-30-2015, 09:03 PM   #157
Xero-Limit
Xero-Limit's Avatar
Hey guys, just a refresher for anyone shopping around for kits. We're getting these questions frequently so here's the answers again:
Is the kit plug and play?
YES. The instructions need to be updated, but there is no splicing or anything. Just plug the components in. Please do not cut any wires! Instructions are still valid on hooking up the fuel lines and where to plug in the power and ground.
Rear O2 vs EVAP:
Half dozen in one 6 in the other -- but the rear o2 is cheaper. We retain the power feed from the fuse block and not the ECU with either options. So no worries on voltage offsets or anything of the sort. If you are planning on doing an auxiliary wideband, then definitely go for the rear o2 so you can plug in the evap.
Is a free tune included?
Only for our existing customers. We will enable flex fuel functionality on your existing tune. If you've made other changes with parts purchased from another vendor, then a revision or a new tune will need to be purchased. A $579 flex fuel kit does not include a $799 tuning suite!
That is all, happy boosting everyone!
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post:
BigFatFlip (09-30-2015), Bramick (10-02-2015), onzippy (09-30-2015)
Old 01-04-2016, 02:56 PM   #158
FT_86_SM_GP
FT_86_SM_GP's Avatar
Drives: Lawn moweR
Hi,
Does this kit also 'plug and play' for RHD vehicles (Toyota 86's in Europe / Japan / South Africa)
Or does this kit need to be adjusted?
Thanks
FT_86_SM_GP is offline
The Following User Says Thank You to FT_86_SM_GP For This Useful Post:
Xero-Limit (01-05-2016)
Old 01-05-2016, 01:52 PM   #159
Xero-Limit
Xero-Limit's Avatar
For JDM/RHD vehicles with the hoses instead of push on fittings, we have a custom kit that uses the correct size hose instead of the "almost" correct AN lines. Just make sure to contact us when you place or your order and we'll set it up that way.
Old 02-08-2016, 10:39 PM   #160
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
As if I didn't have enough stuff on my list of "want but can't afford" components, I'm liking the look of this. I do have a few noobish questions though.
This one is one of those "who cares?" kind of questions. What kind of mileage are people getting with this setup with corn in the tank?
And I see a bunch of people asking about tuning. I know nothing on the subject, so sorry if this sounds stupid. If I just want to plug all my stuff in (this, all my exhaust pieces) and have a tuner shop do all the tuning, I want nothing to do with it, what software/hardware do I need? Do I need that license and all the maps and stuff?
Nevermore is offline
Old 02-08-2016, 10:57 PM   #161
steve99
Drives: FT86
On E85 you will get about 25% worse economy than petrol
for flex fuel you will need
The Flex fuel kit including fuel lines flex sensor and cabling and possibly ethanol display.
You will then need the ECU software and settings (tune) to read and interpret the flex sensor readings.
Tune aprox $300
Ecutek ECU licience about $350
Ecutek cable to write/flash the tune to your ECU about $350, this is not needed if you go to tuner as they will flash it for you.
I believe some flex kits include the price of a tune, but probably dont include ECU licience.
steve99 is offline
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Nevermore (02-08-2016), Xero-Limit (02-09-2016)
Old 02-09-2016, 06:51 PM   #162
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Tune aprox $300
This kit includes all the lines, right? The only components I'll need is the kit itself?
Old 02-09-2016, 07:30 PM   #163
Xero-Limit
Xero-Limit's Avatar
You got it, the kit is sold complete and with the better AN lines. You can choose rear o2 for the easiest install, or you can do the evap option for slightly more precision and leaving the rear o2 to do its job in closed loop. Tuning/license is extra as @steve99 mentioned above.
Nevermore (02-09-2016)
Old 02-09-2016, 07:36 PM   #164
tracerit
Drives: '13 SSM BRZ Limited 6MT
Are there any downsides to going thr rear o2 route?
tracerit is offline
Old 02-09-2016, 10:29 PM   #165
steve99
Drives: FT86
I believe the rear 02 input is used to detect primary cat efficiency and for minor AFR adjustments during cruising (ie on highway)
The tune will disable and CEL codes and i believe remove any reference to rear 02 input. This may have a very minor effect on highway cruise economy.
Evap input wont effect this, however it will still be re-purposed in tune so not available as evap input to ecu
I believe you will still fail readiness tests if either rear 02 or evap is used as flex sensor input as these tests wont complete in the normal way.
AFAIK no tune system forces readiness test to complete when input has been re purposed or disabled.
steve99 is offline
tracerit (02-09-2016)
Old 02-11-2016, 10:32 AM   #166
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
This is the first time I've heard of this. So regardless of whatever option, FF kit will cause the OBD-II/O2 system to never achieve readiness state? I'd fail inspection in Texas for that (and have with previous car)
Jyn is offline
Old 02-11-2016, 01:09 PM   #167
kch
Senior Misanthrope
kch's Avatar
we get a freebie. it's the second "not ready" that fails you.
kch is offline
The Following 2 Users Say Thank You to kch For This Useful Post:
Jyn (02-12-2016), Xero-Limit (02-11-2016)
Old 02-11-2016, 03:24 PM   #168
gl2filmerguy
gl2filmerguy's Avatar
Drives: 2013 Ultramarine FR-S
I'll be buying these as soon as Shiv gets the tune ready for the SBD turbo kits!
gl2filmerguy is offline
The Following 2 Users Say Thank You to gl2filmerguy For This Useful Post:
DustinS (02-11-2016), Xero-Limit (02-11-2016)
e85, ethanol, flex fuel
Moto-East (Moto Mike) Review Thread ecko04 User/Vendor/Sponsor Reviews, Feedback, Comments 4 05-22-2014 07:57 PM
GReddy Turbo Kit Now Available at Moto-East! Xero-Limit Forced Induction 1 12-27-2013 02:20 PM
Moto-East E85 Testing Xero-Limit Engine, Exhaust, Transmission 11 07-23-2013 04:55 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 10:36 AM
Moto-East tune -wow Evil86 Engine, Exhaust, Transmission 2 03-13-2013 02:02 PM
