Old 02-05-2016, 02:34 AM   #1
Dico
Drives: SUBARU BRZ
Weird issue with my 13' Subaru BRZ
After adding an oil cooler here in China, there was a very weird issue with starting my car.
Issue:
I have to put my clutch pedal to the floor, hold "Stop Start" button about 30 seconds, then engines started.
Normally the car should start immediately when press the "Stop Start" button as all your cars, but now I should hold the button for 30 seconds every time like an idiot
Dose anybody know why this issue happened? I'd checked my ecu chip, the whole electronics system, the battery, the starter, etc, nothing wrong, all of them are OK. It kills me...everyday
HELLLLLLLP
Dico is offline   Reply With Quote
Old 02-05-2016, 02:38 AM   #2
ryoma
ryoma's Avatar
does the engine crank while you're holding down the start button, or is there no reaction until 30 seconds later?
Old 02-05-2016, 02:57 AM   #3
Dico
Drives: SUBARU BRZ
no reaction, nothing happened until 30 seconds later, crank and start
Old 02-05-2016, 03:36 AM   #4
ryoma
ryoma's Avatar
push your start button twice to turn the engine electronics on, wait a few seconds, then push in your clutch and push the start button again and see if it starts. maybe it might be a bad connection with your key fob or actual start button? what year is your car?
Old 02-05-2016, 06:02 AM   #5
............what year is your car?
He mentioned in the title it's a 2013.
Old 02-05-2016, 10:48 AM   #6
Dico
Drives: SUBARU BRZ
i tried that, not work. start button checked, no issues.
the key fob, the key fob, maybe it was out of battery? i bought this car 2 years ago and lost the backup key fob.
Is there any thread about how to change the key fob battery? Thanks!!
Old 02-05-2016, 11:32 AM   #7
kch
Senior Misanthrope
kch's Avatar
Not sure about replacing the battery. But you can just hold the key up against the start button next time you try to start it. That's the secondary method of starting the car when your battery dies.
Old 02-05-2016, 01:22 PM   #8
extrashaky
Drives: 2014 BRZ Limited
You've lost almost a foot off your car!
Old 02-07-2016, 11:36 PM   #9
Dico
Drives: SUBARU BRZ
replaced a new battery, but the same issue. i went to the local dealer for help, they checked 3 days, nothing was found.
hmmm...very weird
Old 02-07-2016, 11:58 PM   #10
Tomahawk
Drives: 13 FRS
I had this happen just a week ago. Dealer found out the immobilizer actually went bad on my 13 frs.
Tomahawk is offline   Reply With Quote
Old 02-08-2016, 12:19 AM   #11
Dico
Drives: SUBARU BRZ
Thank you so much, Tomahawk, i will drive to SUBARU dealer to replace a new immobilizer. How much of a new immobilizer?
Old 02-08-2016, 10:37 AM   #12
Tomahawk
Drives: 13 FRS
Well I had to get mine towed there since the immobilizer wouldn't pick up the key. It cost me $460
Weird hot start issue mike the snake Software Tuning 21 01-18-2021 07:03 PM
Weird template issue after 131 update fantah Software Tuning 5 03-31-2016 08:57 PM
Weird site issue Impureclient Site Announcements / Questions / Issues 14 06-18-2015 04:40 PM
Weird issue with oft not reading cel fenton Software Tuning 7 09-14-2014 12:26 PM
weird issue after BPB & OFT install DAN_BRZ Engine, Exhaust, Transmission 10 06-10-2014 09:53 PM
