Old 09-12-2014, 08:56 PM   #1
fenton
Weird issue with oft not reading cel
Just had a cel come up but the oft said no cel present. Cycled both the car and the oft multiple times to no avail.
I'm pretty sure it is the same code I have been getting for a bit now which is the ignition coil 1 error p0351. Need to get the dealer to check it out.
I ended up flashing the newest ROM that I hadn't flashed yet and that cleared it.
Anyone see this with OFT before?
@Shiv@Openflash
fenton is offline   Reply With Quote
Old 09-13-2014, 12:37 AM   #2
steve99
@Shiv@Openflash
OFT only reads codes from Engine ECU, if code is from other computer ie body control unit it will say no codes.
OFT will clear all codes though.
Read the code with torque or similar.
flashing a rom resets ECU and hence clears codes.
Old 09-13-2014, 01:14 AM   #3
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
@Shiv@Openflash
Do you have an automatic transmission? If so, flashing the ECU will trigger a CEL (transmission control unit fault). This is normal and it will clear after a little bit of driving. During this time, the OFT will not read any codes (since it's not engine related).
Old 09-13-2014, 09:07 PM   #4
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
Interesting - I have an AT and I have never seen this happen.
VR46 is offline   Reply With Quote
Old 09-13-2014, 10:46 PM   #5
phrosty
It's uncommon. I saw it the first time I flashed, none of the several times after that.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 09-13-2014, 10:59 PM   #6
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
@Shiv@Openflash
You will still be under warranty ? What other mods do u have
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 09-13-2014, 11:03 PM   #7
Shiv@Openflash
Drives: 2013 FRS
@Shiv@Openflash
The code shouldn't be ROM related. Most likely a bad coil which is something i've heard reports of before.
Old 09-14-2014, 12:26 PM   #8
fenton
No auto. The CEL happened when it was wet out and I lost traction in first gear.
I just thought it was very strange that a cel popped up and I wasn't able to see it or reset it with the tablet.
Flashing the newest map resolved it just because it wipes everything when flashing a new ROM.
The p0351 keeps coming up at higher rpms and from what I read here it is pretty common. Going to take it into the dealer next week.
weird issue at high speeds after OFT tune dejxx Software Tuning 24 08-10-2014 09:49 PM
OFT ECU reading issue fantah Software Tuning 2 06-11-2014 03:46 PM
weird issue after BPB & OFT install DAN_BRZ Engine, Exhaust, Transmission 10 06-10-2014 09:53 PM
Any way to mod the speedo MPH reading? Tromatic Cosmetic Modification (Interior/Exterior/Lighting) 7 06-24-2013 10:34 PM
Reading Vin # Knightmare BRZ First-Gen (2012+) — General Topics 2 11-16-2012 01:26 PM
