Old 06-11-2014, 12:11 AM   #15
jflogerzi
jflogerzi's Avatar
Originally Posted by Sookainian View Post
Will this spacer fit the stock 17" rims ?
Anyidea does the stock 17" rims have the "pocket" for the nut sit in ?
Yes they do. I will post a pic for you shortly.
Old 06-11-2014, 12:11 AM   #16
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
These spacers have zero interference with the OEM wheels. I did have a minor nut imprint on the back of my Volk SE37k with the 20mm spacers (didn't come close with the 30mm spacers).
mit_peid is offline   Reply With Quote
Old 06-11-2014, 12:13 AM   #17
Sookainian
Sookainian's Avatar
Drives: Toyota GT86
Photos will help a lot ~ thank u
Sookainian is offline   Reply With Quote
Old 06-11-2014, 12:23 AM   #18
jflogerzi
jflogerzi's Avatar
Here you go
Stock Rim (2013 FRS)
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
Astroboy (09-14-2015), Sookainian (06-11-2014)
Old 01-26-2016, 06:20 PM   #19
HachiRo
Drives: 2013 White-Out FRS
Bringing back an old thread instead of posting a new.
With H&R Hubcentric spacers, I just put the original studs through the holes of the spacer and bolt them down correctly right? As the spacer will have it's own studs? Or would it require me to install extended studs?
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 01-26-2016, 06:25 PM   #20
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Bolt'n go buddy
HachiRo (01-26-2016)
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 12:59 PM
Wheels and tires Question flameSniper Southern California 9 12-20-2012 03:07 AM
Question: how to ship wheels? Cornell89 Wheels and Tires 3 08-16-2012 09:56 AM
N00b Question: what do you do with the OEM wheels, should you get aftermarkets? G4mb17 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 06-16-2012 06:01 AM
Wheels Question Tsinoy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 01-19-2012 02:45 AM
