Old 01-06-2016, 10:38 AM   #15
speeddemon
Drives: Scion frs
I have this jack and love it. My old man had two jacks; one didn't lift high enough to get stands under, and the other was too high to get underneath it. I would use one jack to get underneath it and then the other to lift it up high enough lol (not recommended of course). For the money you can't beat this deal. Low profile, lifts high, and it's 3 ton! I got a warranty just in case because the quality with these is sparatic; some will last forever, others will go in a few uses.
speeddemon is offline   Reply With Quote
Old 01-06-2016, 12:44 PM   #16
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Y'all wanna share additional links? I was looking at the 2TON extended but whoo, $140, I'm making due with a 2Ton jack that looks like this one:
http://www.northerntool.com/shop/too...oJTxoC_Jfw_wcB
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 01-06-2016, 01:03 PM   #17
stevesnj
stevesnj's Avatar
I use this jack on my 5700lb Landcruiser so thats why i got the 3ton, but if you just have the car get the 2ton.
My 2016 Build thread
Old 01-06-2016, 01:05 PM   #18
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Really shouldn't matter. You shouldn't be lifting your entire car on the jack (one half of the weight usually stays on the ground when you lift).
2 ton is good for most applications -- although best not to get near the max of the jack (leave 20% of total weight capacity free)
ajcarson11 is offline   Reply With Quote
Old 01-06-2016, 01:11 PM   #19
Ashikabi
Ashikabi's Avatar
I have 2 ton. Too tall to fit under car now... I suggest getting a low profile aluminum one instead. Mine is HEAVY
Old 01-06-2016, 01:42 PM   #20
stevesnj
stevesnj's Avatar
well the rear of my truck weighs about 2800 so I play it safe. I don't think it's possible to lift an entire vehicle with one hydraulic jack anyway lol
Old 01-06-2016, 03:58 PM   #21
CatDaddysBBQ
Drives: '13 FR-S
I actually bought their 2-ton version that has a longer arm than this one. Even with it's lower weight rating, it was more expensive and the longest travel from fully down to fully up they offer. Ive already used it a few times since bought it 2 months ago and totally love it.
I got tired of re-buying jacks every time I got a new car. This made my other two floor jacks kind of pointless to own, but eh - now I don't have to think about it again. Now, if the damn thing didn't weigh 100lbs...
CatDaddysBBQ is offline   Reply With Quote
The Following User Says Thank You to CatDaddysBBQ For This Useful Post:
Nickosport (01-06-2016)
Old 01-06-2016, 04:44 PM   #22
SHIFTEVO
Drives: Lightning Red
I got one last month..perfect for lowered cars but man them wheels are so rough on concrete...
SHIFTEVO is offline   Reply With Quote
Old 01-06-2016, 07:53 PM   #23
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
I use this Craftsman 2 1/2 Ton Low Profile Jack from Sears. Kind of a sucky short arm and relief knob for lowering, but hey, it's $62.99.
Luftwaffel is offline   Reply With Quote
Old 01-06-2016, 07:58 PM   #24
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
So I've been using the 3 ton hf without issues on stock height 86. Clearance is very close already. If I install TRD lowering springs, which I understand provide just under a 1" drop, will this floor jack still work? I feel like I'm reading some contradictory testimony and this thread is proving relevant.
Thx
Toyarzee is offline   Reply With Quote
Old 01-06-2016, 08:25 PM   #25
Ashikabi
Ashikabi's Avatar
Thx
Get a low profile or race ramps
Old 01-06-2016, 08:38 PM   #26
Toyarzee
Shibby!
Toyarzee's Avatar
It is a low profile jack. Just wondering if it's low pro enough.
Not concerned with rear, but when sliding the jack under the front jack point, the reach is so far that you start to slide the non low pro mid section under the front clip
Old 01-06-2016, 08:46 PM   #27
Ashikabi
Ashikabi's Avatar
Put your jack under and measure. If you have an inch you're fine. If not... race ramps
Edit: if you're only an inch or so short, just make some "ramps" out of 2x4s or something. Anything to get an extra inch or whatever. Keep it cheap and light
The Following User Says Thank You to Ashikabi For This Useful Post:
Toyarzee (01-06-2016)
Old 01-07-2016, 06:12 PM   #28
SmartedPanda
Trying to get one around the same price that is lower and longer, but they're usually 40-60 more.
Main appeal is lowest point, price and length.
WTB: Low profile floor jack and jack stands! lupindub Want-To-Buy Requests 2 11-26-2015 11:03 PM
Harbor Freight Jacks White64Goat Other Vehicles & General Automotive Discussions 28 12-27-2014 07:16 PM
Harbor Freight Low Profile Jack on sale $139 DarrenDriven Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 10-06-2014 06:18 PM
$10 Harbor Freight Catch Can ML Engine, Exhaust, Transmission 58 09-24-2013 01:31 PM
Aluminum 1.5 Ton Racing Jack on sale at Harbor Freight Foobar Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 11-22-2012 01:42 PM
