Old 01-05-2016, 06:10 PM   #1
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Harbor Freight - 3 Ton Low Profile Jack
Not sponsored nor work for Harbor Freight.
Just saw this in my inbox and wanted to share. I might pick this up after work.
Just wanted to share during work, and see if there's any opinion
http://www.harborfreight.com/oct-tab1.html
http://www.harborfreight.com/3-ton-L...fQ%3D%3D%0D%0A
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 01-05-2016, 06:19 PM   #2
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
Nothing wrong with this so long as you understand you are getting Harbor Freight quality. Some of these last a long time. Some break in a year. But for 80 bucks, not a bad deal. Even if it breaks, HF will replace or credit I think. If you have your receipt.
I use the 1.5 ton Aluminum. It's enough for the BRZ and is a lot easier to move and store.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
Old 01-05-2016, 06:32 PM   #3
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
F*ck*ngmotherf*ck*ngb*tcha*sf*ck*ngsh*t.
I just bought a 1.5 ton from them for 70-80 bucks not too long ago... I would rather have taken this deal for the 3 ton. Damn.
Sorry for the profanity
Instagram: trevor.parque
SmartedPanda (01-05-2016)
Old 01-05-2016, 06:42 PM   #4
SmartedPanda
Pittsburg = HB brand? I had most of my tools stolen 2 years ago, some slowly re-buying stuff. Craftman Floor jack failed on me so I'm trying to expand my brands.
for the input!
Old 01-05-2016, 07:16 PM   #5
8R6
8R6's Avatar
Drives: FRS
pretty good deal for $80. i got a 1.5ton from them a year ago for around $60-70 and was considering this one instead, but 75 lbs seemed too inconvenient to lug/push around for just simple garage use at home. still a good deal tho.
8R6 is offline   Reply With Quote
Old 01-05-2016, 08:59 PM   #6
stevesnj
stevesnj's Avatar
I have this jack and even lowered with TRD lowering springs it still rolls under. Get it asap! It is heavy.
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
BigHugeFatGuy (06-05-2018), SmartedPanda (01-05-2016)
Old 01-06-2016, 07:00 AM   #7
Alan
Alan's Avatar
for the input!
Yes, Pittsburgh (along with most of the other brands sold at HF) is an HF brand.
Things I use only occasionally or can afford to replace frequently I buy at HF (nearly free volt meters, track tools, air tanks, jacks, tarps, etc). Or things that have no quality issues (jack stands, nitrile gloves, simple storage etc.). I won't buy electrics at HF.
Things I want to keep and need to be good quality, I buy elsewhere. Usually Craftsman. (Torque wrenches, sockets, ratchets, screwdrivers etc).
The Following User Says Thank You to Alan For This Useful Post:
DrDuquette (01-06-2016)
Old 01-06-2016, 08:34 AM   #8
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
The lightweight one is much nicer. I have this one, the orange heavy ass low profile one and the 129.99 lightweight aluminum one. I have the warranty on the aluminum one and Every 6 months or so I go back and get a new one and get a new warranty($20) so it's like a i lease the jack.. But its always in mint condition, meanwhile the other two jacks i purchased with no warranty sit there and leak fluid all over.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 01-06-2016, 09:11 AM   #9
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
I have issues with 3" clearance. If you want to lift the front of the car, the reach to the jack point is far under. I have to get my car on ramps first. Custom ramps I made. I should post them.
DrDuquette is offline   Reply With Quote
The Following User Says Thank You to DrDuquette For This Useful Post:
vintagemxer (01-01-2018)
Old 01-06-2016, 09:15 AM   #10
tcai1976
tcai1976's Avatar
Drives: 2015 FR-S Hot Lava
I have the HF 2-Ton Low Profile Long Reach as seen:
http://www.harborfreight.com/2-ton-l...ump-60678.html
I have TRD Springs lowered 7/8" to 1" with the 5:AD Front Bumper Lip, Borla Catback, and one of those common E-Bay Rear Diffusers.
Using the front and rear jacking points there are issues even with the extended reach. *Edited to say I can post pics to illustrate what I'm talking about.
Jacking up the front: Even with the long reach I have perhaps 1/2" to 3/4" clearance from the center area of the bumper to the side guards of the jack arm.
Jacking up the rear: The long metal arm used to jack the car needs to be started parallel to the ground, slid underneath and positioned at a 25-degree angle to avoid touching the lowest part of the Borla cat-back pipe. The first few pumps I only move the arm 3-4" at a time to avoid banging into the diffuser.
You could get away with the 3-ton if you don't have an body kit mods that extend your front lip or lowers your diffuser.
And/or have custom ramps per DrDuquette's suggestion.
tcai1976 is offline   Reply With Quote
Old 01-06-2016, 09:22 AM   #11
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
2 Ton variant is slightly lower.... Ive had it for 2 years now and its been a champ!
Cockatoo is offline   Reply With Quote
Old 01-06-2016, 09:32 AM   #12
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I have two of the jacks this thread is about, and one of the typical aluminum low profile jacks. None of them have ever let me down, I got one warranty for the 3 ton jacks, I figure the aluminum one is so cheap I may as well just get a new one when it fails. I've had the aluminum one for about 4 years with fairly hard use, and the steel ones for about 1.5 years with fairly hard use.
I'm a fan of them all.
Edit: The steel one can reach under the front of my BRZ with swift springs, and an STi lip no problem.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 01-06-2016, 09:50 AM   #13
Nickosport
Drives: 2015 WRB BRZ Premium
I have the Aluminum one that I keep in my race trailer and take to the track with me. It works pretty well. I have had it for 5 years and haven't had any issues. Its a bit too short to get to jacking points on the BRZ though. My car is roughly 1" lowered and lips/skirts all the way around, and I've never had an issue with the height. I have a 3.5 ton steel jack in my shop, but the height is too tall to get under an 86.
I'm going to buy one of the 2 ton low profile jacks that HF sells with the long reach to replace my steel one. The long reach should make it easy to reach the front jacking point and under the diff, even with lips and diffusers.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
Old 01-06-2016, 10:25 AM   #14
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
2 ton variant is slightly lower. I have this jack in the 2 ton. It is superb. It may be heavy, but it is lower profile than the aluminum equivalents.
Great jack -- Would recommend it.
ajcarson11 is offline   Reply With Quote
WTB: Low profile floor jack and jack stands! lupindub Want-To-Buy Requests 2 11-26-2015 11:03 PM
Harbor Freight Jacks White64Goat Other Vehicles & General Automotive Discussions 28 12-27-2014 07:16 PM
Harbor Freight Low Profile Jack on sale $139 DarrenDriven Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 10-06-2014 06:18 PM
$10 Harbor Freight Catch Can ML Engine, Exhaust, Transmission 58 09-24-2013 01:31 PM
Aluminum 1.5 Ton Racing Jack on sale at Harbor Freight Foobar Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 11-22-2012 01:42 PM
