Drives: 13 White MT FR-S
$10 Harbor Freight Catch Can
Picked this up at harbor freight for $8, got two 1/4" end fittings from auto store, gutted the inside of the "filter", reversed the spring to the outside of the "filter", and BAM...catch can.
This is after the first drive. (hour long drive) Yes, the zip ties are going away today. ![]() p/n #68225
| The Following 6 Users Say Thank You to ML For This Useful Post: | 6speed_Sam (08-14-2013), hyper4mance (08-13-2013), JDKane527 (08-13-2013), mikochu (08-13-2013), solidONE (08-14-2013), Wes (08-13-2013) |
Drives: WR Blue BRZ, 240Z
It aint pretty, but it sure is clever.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
| The Following User Says Thank You to Gary in NJ For This Useful Post: | ML (08-13-2013) |
#4 | |
Drives: 2013 Raven FRS
Tint, nothing! I think it's cool seeing through it.
Nice. You have a pic of the spring reversal?
Sent from a Motorola DynaTAC 8000X Last edited by Yruyur; 08-13-2013 at 12:14 PM. |
Boosted
Drives: Not a supra....yet
Zip ties don't have to go. They do the job perfectly fine
Thupercharged
I ran one of these on a budget build I did a while back except I used a steel pot scrubber to catch the oil.... same thing thats stuffed into valve cover vents on smallblocks to vent pressure but trap oil
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
i've used those before. all the function, none of the bling. just the way i like it
| The Following 2 Users Say Thank You to jamesm For This Useful Post: | charged86 (08-20-2013), Dephective (08-20-2013) |
I don't, but Its very simple though. It comes with the valve in the bottom always open which is bad. So disassemble the bottom, and take the spring out. then put it back together and put the spring between the bottom ring nut and the clip. Provides enough pressure to seal the inside.
#10 |
Drives: Silver AT Limited
genius! Needs some duct tape to complete it
#11 | |
Sent from a Motorola DynaTAC 8000X |
#12 |
Drives: 13 Whiteout
This is full of Win! Thanks.
2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned. Less parking more racing |
#13 |
You just push on the bottom and the valve opens, so you wouldn't need one, unless you had something else in mind.
#14 | |
| Freight charge on Scion FR-S? | euroshowoff | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 04-25-2013 10:36 AM |
| Oil Catch Can.? | Cjs_ | Engine, Exhaust, Transmission | 18 | 02-28-2013 11:58 PM |
| Remember Pearl Harbor today | ML | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 12-07-2012 09:40 AM |
| Aluminum 1.5 Ton Racing Jack on sale at Harbor Freight | Foobar | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 11-22-2012 01:42 PM |
| Museum and Harbor Panaromas (caution wide) | Dadhawk | Other Vehicles & General Automotive Discussions | 0 | 04-08-2012 05:20 PM |
