Old 12-15-2014, 08:28 PM   #1
White64Goat
Harbor Freight Jacks
Got an e-mail today from HF with more sales ads and they are advertising the 3 ton low profile (steel) jack for $92. The 2 ton is $139 (which makes no sense) if you're looking for a jack. The regular size 3 ton is $79.99 with the coupon.
Old 12-15-2014, 08:36 PM   #2
swarb
Price is with coupon.
Old 12-16-2014, 07:02 AM   #3
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
A fair warning though: If you get the regular non-low-profile jack and have your car lowered an inch or more, you'll need to drive it onto wood blocks to fit the jack under.
FReSh is offline   Reply With Quote
Old 12-16-2014, 05:12 PM   #4
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
I bought the 1.5ton Aluminum racing jack for USD59.99 (USD89.99 with a USD30 coupon taken off).
Doesn't say it's low profile, but the minimum height is about 3.5in, which is fine for a stock car (I think our clearance is about 4-4.5in).
The weight difference is significant - the steel jacks weight close to 100lbs, while the aluminum jacks all come in under 40lbs.
Not to mention, I don't think we need 2.5T jacks to lift up our cars (though if you own heavier vehicles, you may want one).
Only downside: the 1.5T aluminum jack only lifts to about 14in.
daiheadjai is offline   Reply With Quote
Old 12-16-2014, 05:23 PM   #5
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
if you get these, it's worthwhile to remove the shit ass button head screws holding the front roller in and replace them with actual grade 8.8 or 10.9 socket head cap screws, blue loctite them in for good measure and torque them well. I have had the screws back out and the jack fall apart while using it before.
just make sure to get stands also and ALWAYS be safe while using this jack. obviously you should be safe with any floor jack, but especially so with this one because you're likely to have something bad happen eventually with them.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 12-16-2014, 05:29 PM   #6
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
The 3ton isn't the jack you want. You want the 2 ton since it fits under the lowest cars and has the longest reach.
http://www.harborfreight.com/2-ton-l...ump-68050.html
That's the one you want.
post_break is offline   Reply With Quote
The Following User Says Thank You to post_break For This Useful Post:
HATED1 (12-26-2014)
Old 12-16-2014, 09:33 PM   #7
FRSupra
FRSupra's Avatar
I've heard that the lower priced and lower weighted HF jacks have a history of slowly dropping on their own.
Don't cheap out on a jack.
FRSupra is offline   Reply With Quote
Old 12-16-2014, 09:53 PM   #8
post_break
post_break's Avatar
Can you recommend a different jack that has 40 inches of reach and 2" 5/8 minimum height?
I looked high and low and didn't find anything, even in the $300 range.
Old 12-16-2014, 09:55 PM   #9
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
I got 2 of the 3 ton low profile steel jacks on sale a couple months ago for $79.99/ea. Lowest price I'd ever seen them.
Kotu100 is offline   Reply With Quote
Old 12-16-2014, 10:01 PM   #10
FRSupra
FRSupra's Avatar
Did you try Michelin jacks?
Old 12-16-2014, 11:08 PM   #11
LSxJunkie
LSxJunkie's Avatar
Drives: Car
I love my 2 Ton HF. But I never use only the jack. I always back it up with a jack stand, the wheel/tire I removed, or ideally, both, under the rocker.
LSxJunkie is offline   Reply With Quote
Old 12-21-2014, 08:39 PM   #12
Model Citizen
Lacking brains
Drives: frz
Both my harbor freight jacks have been phenominal
Have the little aluminum racing jack for about 7 years and thelowlong reach steel for most of a year.
Wouldnt know if they lower over time cause im not a dipshit that leaves the vehicle supported by the jack
Jacks are for lifting it up and lowering it down, not resting.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
The Following User Says Thank You to Model Citizen For This Useful Post:
LSxJunkie (12-22-2014)
Old 12-23-2014, 12:30 PM   #13
daiheadjai
daiheadjai's Avatar
Yeah - I don't get this - even the jack will instruct you to always use the jackstands to support the vehicle...
Old 12-23-2014, 01:23 PM   #14
wheelhaus
wheelhaus's Avatar
Correct, the 2-ton (# 68050) is the one you want, very very long, and very very low profile, perfect for jacking from the front crossmember and then the rear diff, car is in the air on jackstands in a couple minutes.
Because the reach is much longer, it's rated load is lower. Unfortunately it hasn't been cheaper than $129/139 in nearly a year (it's been on sale prior to that for $99/109 about a year ago, so here's hoping for those who don't have it).
Mine has worked GREAT for the last couple years, no leaks, no slow drops, its built quite well. The valve is touchy, very small window of open/closed, so be careful until you get the hang of it. I cut a hard rubber disk to go in the center of the lifting foot to avoid gouging anything. Be wary, it's freaking heavy (102 lbs) so make sure you have a happy place on the floor for it to live, lol...
wheelhaus is offline   Reply With Quote
The Following User Says Thank You to wheelhaus For This Useful Post:
DarkSunrise (12-23-2014)
Is a catback install possible with just jacks? jflogerzi Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 43 02-20-2021 09:45 AM
Harbor Freight Low Profile Jack on sale $139 DarrenDriven Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 28 10-06-2014 06:18 PM
$10 Harbor Freight Catch Can ML Engine, Exhaust, Transmission 58 09-24-2013 01:31 PM
Aluminum 1.5 Ton Racing Jack on sale at Harbor Freight Foobar Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 11-22-2012 01:42 PM
Are my accessory jacks plugged in? dale.m Electronics | Audio | NAV | Infotainment 3 10-09-2012 12:14 AM
