Old 01-08-2014, 11:57 AM   #15
Kodename47
Kodename47's Avatar
Drives: UK GT86
Did anyone create a good accurate-ish calibration for this? I've had a go based on my dyno wideband results from the weekend but I know that tailpipe generated results won't be as accurate, so I'd like to see what other have done.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-05-2014, 08:36 PM   #16
ztan
Drives: Toyota 86
Resurrecting this thread.
Looking down the Denso doc that arghx7 shared, I see more extended curves later on.
Also looking at stock and Shiv's 1.59 O2 scales, looks like there is a lot more data that can be plugged into the bottom end of the scale, with the 3 cells over 0.43mA not being needed.
Has anyone benchtested the particular sensor that we have and give us scaling values for the rich end of the scale in better resolution?
Off the paper curves (which don't match stock ROM values):
AFR mA
10 -1.8
11 -1.25
12 -0.8
13 -0.45
ztan is offline   Reply With Quote
Old 11-06-2014, 02:30 AM   #17
Kodename47
Kodename47's Avatar
Drives: UK GT86
EcuTek have and supply it in their documentation....
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-19-2015, 08:00 AM   #18
dave-
Drives: 86 GT
And again! @ztan did you make any progress on the scaling changes? Or even test against a proper wideband?
dave- is offline   Reply With Quote
Old 02-23-2015, 05:45 AM   #19
ztan
Drives: Toyota 86
Only got around to it today:
I had a look at the Bosch 4.9 and Denso curves - they are quite similar in mA vs lambda measurements. Our stock ROM reads quite close to the Bosch curve x 0.61.
Made an extended table for the front O2 sensor scaling that is shown below (working down to a 10.5 limit, next testing a 10.0 limit).
The results of that curve vs a PLX SM-AFR (installed last week) with Bosch 4.9 wideband (units in lambda with range from 0.68-1.38) attached. I think that with the extended scaling, the Denso sensor actually performs quite well. The ECU sensor has a smoothed output and I think that is responsible for the higher variability on the lean quadrant of the chart when switching between fueling and deceleration cut.
The Following 2 Users Say Thank You to ztan For This Useful Post:
dave- (02-23-2015), SkAsphalt (02-23-2015)
Old 12-13-2015, 02:20 PM   #20
g0odspeed
Drives: 2013 Scion FR-S Asphault
Originally Posted by mad_sb View Post
So, it sounds like the upstream sensor is wideband and the downstream sensor is narrow band.
Did you ever find out for certain if the second sensor was narrow band?
g0odspeed is offline   Reply With Quote
Map Sensor Hookup? ft86-UAE Forced Induction 22 01-08-2015 03:56 PM
Is P0108 (MAP sensor) common ? regal Issues | Warranty | Recalls / TSB 0 10-06-2012 12:21 PM
Bad MAF Sensor paulieblaze Scion FR-S / Toyota 86 GT86 General Forum 3 08-23-2012 10:34 PM
How to fool airbag sensor? track_warrior Scion FR-S / Toyota 86 GT86 General Forum 3 07-12-2012 11:46 PM
Stock O2 Sensor d1ck Engine, Exhaust, Transmission 1 07-11-2012 07:16 AM
