Old 07-11-2012, 06:56 AM   #1
d1ck
Drives: Black 2013 FRS
Stock O2 Sensor
So last night I had my ebay BT OBDII reader hooked up to my android phone using torque and I noticed something. There are two different O2 sensor readings there: One is AFR requested (or something to that effect) and AFR Measured. The measured value behaves just like a wideband sensor. The AFR doesn't oscillate like a narrowband setup either. I saw it go as high as 20:1 and during normal cruising is would stay very close to 14.7 to 14.9 with small variations.
If I am correct, and the car is equipped with a factory wideband that would be fantastic! No need to buy / install external wideband for tuning purposes. Just log the factory sensor!
I'll make a graph later today to show you what I mean if necessary.
d1ck is offline   Reply With Quote
Old 07-11-2012, 07:16 AM   #2
xjohnx
Grip>Slip
xjohnx's Avatar
I believe they've already confirmed this in the OpenECU thread.
What's the weight on the passenger seat sensor? Iphone sets off airbag/seatbelt chime NeedsmoreCowbell Scion FR-S / Toyota 86 GT86 General Forum 67 03-28-2013 12:21 PM
TPMS Sensor Part Number or Compatibility civicdrivr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-07-2012 01:06 PM
BRZ stock in BC delsol97 CANADA 8 07-05-2012 09:39 PM
[SYD] Swap my stock GTS 17" for your stock GT 16" wheels eckoflyte AUSTRALIA 11 06-18-2012 08:17 AM
