Old 08-23-2012, 01:37 PM   #1
paulieblaze
paulieblaze's Avatar
Drives: 2013 Scion FRS/Whiteout
Bad MAF Sensor
So I was at work letting my car run outside as I went in the prep shop, when I came out the Skid light was on and the CE light was on. I went to the shop and they are replacing the MAF, does me installing an Injen Intake cause me any problems.
paulieblaze is offline   Reply With Quote
Old 08-23-2012, 09:46 PM   #2
roddy
roddy's Avatar
Drives: '13 Ultramarine
It could be an issue, but may not be. Does Injen use an oiled filter? Sometimes oiled filters (like K&N) can dirty the MAF sensor. This can usually be fixed by spraying the sensor with some electrical contact cleaner. Cheap and easy if that is the problem.
Old 08-23-2012, 10:04 PM   #3
Jordo!
Enjoy it, destroy it.
Jordo!'s Avatar
Drives: Datsun Racing Hen
Probably MAF sensor is fine, but you are getting misreads for one reason or another, leading to high fuel trims.
Jordo! is offline   Reply With Quote
Old 08-23-2012, 10:34 PM   #4
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
How long have you had the Injen? I've had mine maybe 3 weeks now and over 1000 miles and I haven't had an issues.
Jidonsu is offline   Reply With Quote
Fuel pump and speed sensor Tt3Sheppard Issues | Warranty | Recalls / TSB 28 04-20-2017 01:54 PM
TPMS Sensor Part Number or Compatibility civicdrivr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-07-2012 01:06 PM
Understanding the BRZ/FR-S/86 Occupant Detection Sensor Turbowned Issues | Warranty | Recalls / TSB 13 08-27-2012 10:58 PM
How to fool airbag sensor? track_warrior Scion FR-S / Toyota 86 GT86 General Forum 3 07-12-2012 11:46 PM
Stock O2 Sensor d1ck Engine, Exhaust, Transmission 1 07-11-2012 07:16 AM
