Old 12-09-2015, 02:36 AM   #1
azynneo
Howling sound turning
I get this howling / warping air sound when I turn right on my car. I can replicate it almost every single time, any suggestions / advice on what I should look for?
azynneo is offline   Reply With Quote
Old 12-09-2015, 03:01 AM   #2
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following User Says Thank You to Aztec For This Useful Post:
cdrazic93 (12-11-2015)
Old 12-09-2015, 03:16 AM   #3
swarb
You should mention your mods and maybe a pic of how low you are. Also do a visual inspection if you haven't done that already. Have someone ride in your car and stick their head outside and see if it is from the front or rear, left or right side.
Old 12-09-2015, 03:27 AM   #4
azynneo
kw3 coils 1" drop on 18x9.5 4.88 final drive innovate supercharged gruppe-s uel headers flexfuel.
I thought it was after getting my 4.88 installed but it seemed it did that before according to a friend
Old 12-09-2015, 10:06 AM   #5
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Does it sound like it's coming specifically from the front or the rear?
Gear_One_Performance is offline   Reply With Quote
Old 12-09-2015, 11:47 AM   #6
azynneo
Good question! Ill update you on that today when i get my friend to tell me
Old 12-09-2015, 12:28 PM   #7
MrDinkleman
Drives: 2016 Oceanic, "base" model
Are your tires' pressures okay?
MrDinkleman is offline   Reply With Quote
Old 12-09-2015, 12:30 PM   #8
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Might be an alignment issue, tires not pointed in the right direction can make a helluva noise.
ineedyourdiddly
Old 12-09-2015, 12:52 PM   #9
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Noise? Who cares? Why? Becuase racecar!!!
Does it happen at all speeds?
Old 12-09-2015, 01:15 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
It would help if you provided how you replicate this noise.
-alex
Old 12-09-2015, 01:22 PM   #11
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Lets all just take random guesses and see who was right
I think its a wheel bearing
Ultramaroon (12-10-2015)
Old 12-09-2015, 10:13 PM   #12
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Commence the random guessing!
All that FA20 squirrel power finally busted loose:
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following User Says Thank You to Shankenstein For This Useful Post:
go_a_way1 (12-09-2015)
Old 12-10-2015, 02:36 AM   #13
azynneo
i tried replicating the noise today.. couldn't do it.. I was able to do it last night.
I replicated this noise by turning the steering wheel all the way to the right / going slightly up a slope or down from a slope.
Old 12-10-2015, 09:15 AM   #14
bfrank1972
Drives: 2013 FR-S Argento
Sound like it could be tire rub?
Turning the FR-S into a Mustang Soon Areddi Mid-Atlantic 3 09-15-2015 11:31 AM
Foglights not turning on Bergen23 Cosmetic Modification (Interior/Exterior/Lighting) 0 03-26-2015 09:57 AM
Sub pop when turning off car Noob4Life Electronics | Audio | NAV | Infotainment 2 07-27-2013 03:12 PM
TC turning back on after turning it off Xdragonxb0i Issues | Warranty | Recalls / TSB 2 02-01-2013 04:19 PM
AC pump turning on and off BRZY Issues | Warranty | Recalls / TSB 3 11-26-2012 03:17 PM
