Old 11-26-2012, 05:26 AM   #1
BRZY
BRZY's Avatar
Drives: World Rally Blue BRZ
AC pump turning on and off
I noticed the other day after installing my Crawford AOS that my AC clutch pulley turns on and off/catches every 15~30 seconds. It creates a thumping noise that can be heard. I keep wondering if I messed something up while installing the AOS. I went back to double and triple check that the belts are on track, wiring plugged in, and ac pump bolts tighten. The ac clutch pulley does not catch unless the HVAC is on. I have not tried turning on the AC. Anyone have this issue?
BRZY is offline   Reply With Quote
Old 11-26-2012, 06:37 AM   #2
roddy
roddy's Avatar
Drives: '13 Ultramarine
If you have your selector set to anything that includes the windshield, AC will come on automatically. This may be what is happening.
Old 11-26-2012, 02:56 PM   #3
Razz
Razz's Avatar
Drives: Fast
It's normal for the system to turn on and off.
You changed the size of the pull. Now it does this more often.
Razz is offline   Reply With Quote
Old 11-26-2012, 03:17 PM   #4
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
That' normal a/c operation
JesseE is offline   Reply With Quote
Max NA HP on pump gas as of now? jadewbj Engine, Exhaust, Transmission 128 02-17-2016 09:28 AM
Turning the Scion FR-S into an authentic GT86 TRD Kotaku91x Scion FR-S / Toyota 86 GT86 General Forum 27 02-22-2013 08:23 PM
Gearknob turning during quick shifting. Vic_RSA AFRICA 13 11-16-2012 12:48 PM
Here's a weird one...noise hours after turning off sa1126 Issues | Warranty | Recalls / TSB 12 10-12-2012 03:15 PM
Be careful at the pump with E15 Thunderchicken Scion FR-S / Toyota 86 GT86 General Forum 9 08-10-2012 10:33 PM
