Old 07-27-2013, 02:55 PM   #1
Noob4Life
86 Noob
Drives: Firestorm FR-S
Sub pop when turning off car
Anybody else with a system have this problem? My subs pop pretty loud when I turn the car off and the amp shuts off. Even when I turn the radio off first or turn the volume all the way down. Is there a fix and will this hurt the subs? Tried searching "sub pop" and nothing popped up
In case it matters im running a stinger 4g amp kit, bespoke audio upgrade, a Planet Audio 2250d and 2 rockford fosgate p2 10s
Sent from my SAMSUNG-SGH-I317 using Tapatalk 4 Beta
Noob4Life is offline   Reply With Quote
Old 07-27-2013, 03:09 PM   #2
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
The sound you're referencing is your amp turning off.
It won't hurt the sub, it just sounds nasty.
You can try a 5v source for your remote and that will solve it, if your amp supports a remote <12v.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 07-27-2013, 03:12 PM   #3
Noob4Life
86 Noob
Is it bad for the subs or is it okay?
Edit* alright thanks for the info man ill check it out. I have it wired to the brown wite with silver markings per a how to I found on here.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
What offset will not interfere with turning? FRSGeek Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-08-2013 12:20 PM
BRZ radio turning off during music Zaneman Electronics | Audio | NAV | Infotainment 0 06-13-2013 12:10 PM
Turning your Premium into a Limited slizoth BRZ First-Gen (2012+) — General Topics 44 02-17-2013 01:13 PM
TC turning back on after turning it off Xdragonxb0i Issues | Warranty | Recalls / TSB 2 02-01-2013 04:19 PM
AC pump turning on and off BRZY Issues | Warranty | Recalls / TSB 3 11-26-2012 03:17 PM
