Old 11-19-2015, 03:21 AM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by solidONE View Post
-4.5 is crazy
Not really. I'm currently around -3.8 and I am daily driving the car now.
-alex
Old 11-19-2015, 04:50 AM   #16
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
-alex
I'm sure you have the tire budget...
Intent > Content
Old 11-19-2015, 02:24 PM   #17
mav1178
mav1178's Avatar
Camber alone does not kill tires.
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
Cole (11-19-2015), wparsons (09-28-2016)
Old 11-19-2015, 02:55 PM   #18
e1_griego
e1_griego's Avatar
Drives: Many
I actually think I'm having this same problem.
Stock front bar + stock endlinks with MCS singles.
Have shorter endlinks on the way which I suspect will fix it right up.
e1_griego is offline   Reply With Quote
Old 11-19-2015, 05:18 PM   #19
solidONE
solidONE's Avatar
You mean like actually driving in on roads? lol tell us more, @mav1178
Intent > Content
Old 11-19-2015, 06:58 PM   #20
solidONE
solidONE's Avatar
Different length endlink will probably not do anything for clearance at the strut mount since the mounting tab position is unchanged on the strut. Although a smaller, less protruding, upper endlink will give more clearance.
A different length endlink may give you more clearance at the control arm/sway bar side.
Intent > Content
Old 11-19-2015, 07:29 PM   #21
puma
crew chief
puma's Avatar
Drives: Race car FR-S
we have the same problem on our race car with RCE tarmac2 (KW) and stock end link. We had to grind as much material as possible on the endlink so it doesn't touch the body of the car. They have been holding on fine so far for the whole season.
puma is offline   Reply With Quote
The Following User Says Thank You to puma For This Useful Post:
Pat (06-30-2020)
Old 11-19-2015, 08:05 PM   #22
e1_griego
e1_griego's Avatar
Drives: Many
I'm hitting on both sides I think. And I'm going to a shorter and lower profile setup. Will post after it works. I didn't buy off the shelf frs stuff.
Old 11-19-2015, 11:10 PM   #23
Dango1
Drives: WRB BRZ
My street tires wore even at -3 with daily driving. That's why I decided to go further.
Dango1 is offline   Reply With Quote
Old 11-19-2015, 11:48 PM   #24
solidONE
solidONE's Avatar
both front and rear? What kind of tire pressures are you running? @mav1178?
Intent > Content
Old 11-19-2015, 11:49 PM   #25
solidONE
solidONE's Avatar
how much lower than stock are you guys?
Intent > Content
Old 11-20-2015, 03:36 AM   #26
e1_griego
e1_griego's Avatar
Drives: Many
Maybe 1.5"? I'm honestly not sure.
Old 11-20-2015, 04:32 AM   #27
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
I had the same problem. Ran max low and max camber and rubbed.I was too lazy to fix it properly so I ended up taking to that part of the body with a ball pein hammer you can't notice it from inside the engine bay. As to whether you rub or not is usually determined by what coils/endlinks you have. Some coil manufacturers offer camber and height adjustibility without taking into account how this may affect the endlinks. The ones who do set their mounts a little further forward. Getting adjustable endlinks CAN help, but it depends mainly on the profile of the knuckle joint. The standard ones stick out quite alot whereas some aftermarket ones have smaller more compact knuckles.
lukey86 is offline   Reply With Quote
The Following User Says Thank You to lukey86 For This Useful Post:
Krovi (11-23-2015)
Old 11-20-2015, 06:02 PM   #28
solidONE
solidONE's Avatar
^ Hammer fixes everything. lmao!
Bad reception on phone? hit it with hammer. Starter motor not working? Tap firmly with a hammer. Annoying wife won't shut up? Bust out the 10lbs sledge hammer. (edit: tis joke. I do not condone domestic violence) unless dat bitch was axeing fo it
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
lukey86 (11-21-2015)
ST coilovers and front camber bolt question. dito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-01-2015 04:52 PM
FS (MI): Front strano swaybar, rear wrx swaybar Aznsky Brakes, Suspension, Chassis 4 11-04-2014 03:09 PM
Front swaybar endlink problem CyberAkuma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-28-2014 10:15 PM
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 10:32 PM
Knocking after lowering *Solved, swaybar endlink* atledreier Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 02-25-2014 12:59 PM
