Old 06-19-2015, 07:01 PM   #1
dito
Drives: SWP BRZ
ST coilovers and front camber bolt question.
does anyone have whiteline front camber bolt 16mm on st coilover? if so, how much negative camber could u get from it? thanks
dito is offline   Reply With Quote
Old 06-21-2015, 12:36 PM   #2
wparsons
wparsons's Avatar
Not fully comparable, but I have the whilteline lobed camber bolts with slotted stock struts and have -2*, I would imagine that with the ST's (which are slotted stock) and camber bolts you should be in that ballpark too.
flickr
Old 07-01-2015, 03:52 PM   #3
Cop
Cop's Avatar
Drives: 2013 FRS
I was able to get -2.0 with this set up.
Cop is offline   Reply With Quote
FS: Whiteline Front Camber Bolt Kit immaculate Brakes, Suspension, Chassis 5 08-19-2014 05:24 PM
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 09:32 PM
Subaru camber bolt question B-R-Z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 05-06-2014 12:14 AM
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 12:13 AM
