Old 11-15-2015, 06:23 PM   #1
Krovi
Krovi's Avatar
Drives: '14 Midnight Purple FR-S
Lowered on coilovers with camber, front swaybar endlink rubs/binds inner wheel well?
My car is lowered on Tein Mono Sport coilovers and I have a Hotchkis front sway bar, and I've had this problem for a while but I've always kind of been putting it aside without finding a better solution.
Basically what happens is because I need negative camber for increased cornering grip on the track, my strut is pulled too close to the wheel well and my sway bar endlink actually rubs and sometimes binds on the inside.
Has anyone else experienced this and had a solution? I'm using both my coilovers' camber plates and SPC camber bolts to get to around -3 degrees of camber up front.
Here's a little doodle I made on my phone (with my elementary school level drawing skills) to show exactly what happens.
Green is my coilover, orange is the sway bar, blue is the endlink, and the red X is where it hits.
'14 MIDNIGHT PURPLE FR-S 『フェイリス』
Follow me on Instagram @overlim.it
Krovi is offline   Reply With Quote
Old 11-16-2015, 09:25 PM   #2
Krovi
Krovi's Avatar
No one?
Old 11-16-2015, 09:40 PM   #3
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Have you thought about adjustable end links? Are you binding on the control arm?
jawn is offline   Reply With Quote
Old 11-16-2015, 09:46 PM   #4
vroom4
What end links do you have?
vroom4 is offline   Reply With Quote
Old 11-16-2015, 10:44 PM   #5
Dango1
Drives: WRB BRZ
Seen this happen once. Coils were installed wrong left/right. Caused too much castor and endlink to make contact. Maybe check that?
Dango1 is offline   Reply With Quote
Old 11-17-2015, 01:35 AM   #6
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
3 solutions.
1: raise the front ride height so the endlink has enough clearance when suspension is compressed.
2: run less camber so it has clearance when suspension is compressed
3: chop off the endlink mounting tab on the strut then reposition and weld back on the strut so it has clearance when suspension is compressed
Intent > Content
Old 11-17-2015, 08:20 AM   #7
Dango1
Drives: WRB BRZ
I've been testing with -4.5 camber up front (overkill) using combination of top hats and camber bolts and I don't have this issue. Check the parts and install.
Old 11-17-2015, 12:47 PM   #8
solidONE
solidONE's Avatar
Do you have Tein mono sport as well?
Intent > Content
Old 11-17-2015, 03:56 PM   #9
Dango1
Drives: WRB BRZ
Nope. I swap between kw v3's and ground control. I also had neo motorsports in the past.
I've run at least -3 with those setups without issue. I don't run very low though. So I don't think your camber should be the problem and you should check your install just in case. If that's not the case I am out of ideas. Sorry.
Old 11-17-2015, 04:05 PM   #10
solidONE
solidONE's Avatar
Why so much camber? At lease we know v3 and ground control will not have clearance problems.
Intent > Content
Old 11-17-2015, 09:47 PM   #11
Dango1
Drives: WRB BRZ
Track. I don't have to worry abour daily driving the car. I found I was faster with more camber.
Old 11-18-2015, 12:30 AM   #12
solidONE
solidONE's Avatar
-4.5 is crazy, but I've seen a forum member's track s2000 with just as much dialed into the front, even with it's double wishbones. What are your spring rates?
Intent > Content
Old 11-19-2015, 12:02 AM   #13
Dango1
Drives: WRB BRZ
It is crazy. I may dial back a bit next season. I've run spring rates everywhere from stock to 8k. I have been changing a lot to see and feel the effects of chnages.
Old 11-19-2015, 02:20 AM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I like how OP bumps the thread when we give no direct answer, and when we ask for relevant info such as what type of endlinks, he doesn't reply...
-alex
ST coilovers and front camber bolt question. dito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-01-2015 03:52 PM
FS (MI): Front strano swaybar, rear wrx swaybar Aznsky Brakes, Suspension, Chassis 4 11-04-2014 02:09 PM
Front swaybar endlink problem CyberAkuma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-28-2014 09:15 PM
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 09:32 PM
Knocking after lowering *Solved, swaybar endlink* atledreier Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 02-25-2014 11:59 AM
