Old 09-26-2014, 12:41 AM   #1
CyberAkuma
OOH KILL EM
CyberAkuma's Avatar
Drives: FG1 Civic,NA Miata, Whiteout FRS MT
Front swaybar endlink problem
I was trying to install my coilovers today but I could not remove the bottom bolt to remove the endlink, it feels like it's impossible. How did you guys do it?
I am trying to install stance coilovers but the factory endlinks are too long for it.
Any help would be appreciated
Instagram: 8as6
CyberAkuma is offline   Reply With Quote
Old 09-26-2014, 01:03 AM   #2
norcal_brz
Drives: 04 Evo 8 SSL, 13 Brz Limited
You might need to use an allen key
norcal_brz is offline   Reply With Quote
Old 09-26-2014, 08:19 AM   #3
wparsons
wparsons's Avatar
Depending on how old your car is, you'll probably have to cut it off. Even with the proper tools, mine wouldn't come off at all, they were rusted solid.
flickr
Old 09-28-2014, 12:04 PM   #4
muffinz
Drives: 2013 DGM BRZ Ltd
had the same experience when installing my whiteline sway bar.
use a 17mm open ended wrench and a 6mm allen key to stop it from spinning.
my allen stripped out because it was so rusty so i ended up cutting it off with a sawzall
muffinz is offline   Reply With Quote
Old 09-28-2014, 08:24 PM   #5
wparsons
wparsons's Avatar
That's EXACTLY what happened with mine.
flickr
Old 09-28-2014, 09:15 PM   #6
cnk
Drives: '13 DGM BRZ Limited
I removed mine using a Milwaukee M12 Fuel cordless impact. If you don't have an impact, you'll have to do as suggested above and go the open wrench (or pass-through socket if you have it) and allen wrench method to keep it from spinning.
cnk is offline   Reply With Quote
FS (MI): Front strano swaybar, rear wrx swaybar Aznsky Brakes, Suspension, Chassis 4 11-04-2014 02:09 PM
BC Racing Front Adjustable Sway bar Swaybar End Links - $100 shipped STS-V Brakes, Suspension, Chassis 3 08-31-2014 10:01 AM
Stance USA Front Adjustable Sway bar Swaybar End Links - $100 shipped STS-V Brakes, Suspension, Chassis 3 08-31-2014 10:00 AM
Strano Performance Parts 22mm Tubular front swaybar Sam Strano Tracking / Autocross / HPDE / Drifting 276 05-20-2014 02:54 PM
Knocking after lowering *Solved, swaybar endlink* atledreier Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 02-25-2014 11:59 AM
