Old 02-21-2014, 12:30 PM   #1
atledreier
Drives: GT86 DGM
Knocking after lowering *Solved, swaybar endlink*
Just put on my Eibach Pro springs. The springs settled nicely in the seats, and I went over every bolt when putting them on. Everything seemed tight when I put it on, but going over bumps I get knocking in all four corners.
Any tips to where I can go looking?
Edit:
Turned out to be a loose swaybar endlink. I had loosened it to get better access, forgot to tighten it back up.
atledreier is offline   Reply With Quote
Old 02-21-2014, 01:32 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
You didn't tighten your top strut nut enough.
-alex
Old 02-21-2014, 01:36 PM   #3
mackdaddytran
mackdaddytran's Avatar
Drives: Toyota Skyline Type-R
Yeah esp the middle nut
mackdaddytran is offline   Reply With Quote
Old 02-21-2014, 01:41 PM   #4
atledreier
Drives: GT86 DGM
Hm... What torque should I use? I used the guide DarrenDriven made. Maybe my torueqrench is a little low...
I'll go over them again. Luckily they are easy to come by. :-)
Old 02-21-2014, 01:56 PM   #5
fourvalleys
Howdy!
fourvalleys's Avatar
Drives: Party ST, Classic Mini
Whatever you tighten them to, make sure you check it while the car is in the air and on the ground. It will make a difference.
fourvalleys is offline   Reply With Quote
Old 02-21-2014, 01:57 PM   #6
atledreier
Drives: GT86 DGM
ok, I will! Thanks!
Anyone know what torque the manual says to use? And when?
Old 02-21-2014, 02:03 PM   #7
sshole
41 ft-lbs I believe is the torque required for the strut top nut.
You'll need to use a pass-through torque wrench (if you can get one) and an allen key to hold the strut body.
Check all your other fasteners to ensure they are still tight. One that got me worried was the sway bar endlink nut. I used an impact gun on the nut to get it tight, but it ended up backing out a week or so later causing a heinous noise. Went back with a pass-through socket wrench and allen key to tighten it up and all is well.
sshole is offline   Reply With Quote
Old 02-21-2014, 06:25 PM   #8
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Check your tire clearances to the spring and perch. I get noises from my 245's rubbing against the spring when the wheel is turned. 45mm offset with 5mm spacer so effectively 40mm along with -2.6* camber.
Old 02-21-2014, 10:27 PM   #9
lightdir
Drives: 2013 Raven FRS 6MT
could be your swaybar endlinks
lightdir is offline   Reply With Quote
Old 02-22-2014, 02:44 AM   #10
atledreier
Drives: GT86 DGM
Thanks for all the tips, guys!
I'll get some deep pass-through wrench and an allen key to check the strut top nut. That one I just used my impact gun until it seemed to be tight, but could be it just tightened up enough to turn the strut axle.
I'll also make sure to check the endlinks again.
Old 02-22-2014, 09:13 AM   #11
sshole
You blew your struts.
Old 02-22-2014, 09:54 AM   #12
atledreier
Drives: GT86 DGM
How does fastening a nut to an axle blow the struts? I'm just curious.
Sent from my GT-N7100 using Tapatalk
Old 02-22-2014, 10:00 AM   #13
sshole
These struts are extremely sensitive to being spun. If you had looked at any of the DIY spring/strut install threads on this forum, you'd have known from the beginning that many users have reported using an impact gun on the strut top nut has caused their strut to make noise, leak, and ultimately need to be replaced.
You can start diagnosing by tightening the strut top nut the correct way, but if it's still making noise, look for tell tale signs of blown struts - hydraulic fluid leaking, struts compressible by hand, etc.
Old 02-22-2014, 10:02 AM   #14
atledreier
Drives: GT86 DGM
Will do!
I can't remember Darrendrivens how to mentioning that, but I may well have missed it
Edit: just checked, the guide I read specifically mention impact as a useful tool for the top nut
Knocking sound Moe23 Issues | Warranty | Recalls / TSB 80 04-18-2019 08:09 PM
Knocking doesn't sound good :-(. TheMarkness Issues | Warranty | Recalls / TSB 41 02-04-2015 10:38 PM
Knocking on Startup? 636 Issues | Warranty | Recalls / TSB 17 02-03-2014 07:18 AM
Knocking/Rattle on start up. jimbobrand Issues | Warranty | Recalls / TSB 18 01-13-2014 11:34 AM
Knocking sounds from lowering springs? bbaik Issues | Warranty | Recalls / TSB 7 03-07-2013 11:50 PM
