Old 10-29-2015, 04:42 PM   #435
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by smudge View Post
In the UK it's 99RON, not exactly sure how that translates to octane rating but it's around 93-94 from what I've seen
Originally Posted by sato View Post
Octane Rating = (RON+MON)/2
Originally Posted by Kodename47 View Post
Stats on Shell V-Power fuel here are:
99 RON
86 MON
Therefore 92.5 Octane
I have the spec sheet somewhere on my laptop
.: Stealth 86 :.
Kodename 47 DJ:
Kodename47 is offline
smudge (10-29-2015)
Old 10-29-2015, 04:52 PM   #436
bfrank1972
Drives: 2013 FR-S Argento
Dude you are the octane nazi! It's all in the same ballpark
bfrank1972 is offline
Old 10-29-2015, 10:13 PM   #437
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by stockysnail View Post
I'm guessing all you have is a stronger clutch then (aside from flex fuel 700cc injectors and larger fuel pump)? If so which clutch? If so I'm definitely doing this next year with tax returns.
I'm also guessing you could do 2 maps one with the 85mm pulley and one with the 80mm pulley, both flex fueled or are two maps even needed? That way once I upgrade I can swap for track days with e85/92oct street (85mm) or street/autox e85 days (80mm)
We went with the ACT Xtreme plate / organic disk that we carry. It is a stiffer pedal (slightly) but still has an organic like smooth release. I'd say not super smooth, but smooth enough. Street lite flywheel is recommended for the SC cars since that inertia helps even out the blower drag a bit.
You can definitely go with two maps for the pulleys, but honestly I just run one tune. If I want to be "safe" I run the 85mm pulley with the 80mm tune. Automatically a couple degrees retarded on timing (relative to boost) and about 5% richer. So the pulley size drops boost and also makes a safer tune. That's what we've done for the track and long trips etc...
Yes you could optimize an 85mm tune, but it is still around 300 whp and the extra buffer has proven itself on the track. If I want all the power I spend the 3 minutes to swap pulleys back.
Thanks Mike
I'm keen to see what my built motor will run on the 75mm pulley over here in a couple of weeks. And with some testing over winter I think the next step is water/meth injection to keep the temps down without the holy grail that is e85 being available to me
Likewise. May need to do the 72.5 to really get the most out of it if you drop the compression to 10 or below.
Xero-Limit is offline
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
Chad86 (11-07-2015), stockysnail (10-30-2015)
Old 10-30-2015, 05:17 AM   #438
smudge
Drives: Supercharged GT86
See how we get on with the 75mm for now but I'm sure I'll get curious at some point in the future
smudge is offline
Old 11-07-2015, 02:26 PM   #439
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Originally Posted by bfrank1972 View Post
It's what google told me, so it must be right!
I've been running Chevron 94 since I purchased the car.
11,000 MILE UPDATE!!!
Nothing to report
Continues on ticking with no major issues. The new sight glass leaked a bit of fluid so we tightened it back up and no issues. Did some track time in this period and another track day next week, now with an oil cooler and big brakes so it should be less dramatic.
Minimal blow-by from what we see in the radium catch cans.
A few surprised subaru owners who don't understand the merits of instant response in a 60 MPH roll-on...
One surprised owner as to how much the car attracts LEO attention....new radar detector bought.
Otherwise totally issue free since we put this blower on 9 months and 11k miles ago. Even the set of RE-71Rs still has another track day in them. I expected to have been through a trans or some axles by now, but some of that is about how you drive. We regularly utilize our custom RaceROM traction control feature which prevents excessive wheel spin and the subsequent loading that can break axles/gears. Motor is otherwise unchanged in its performance though we will likely build it this winter if we ever finish the WRX.
For those that wonder: Pulley size is about 66% 80mm, 33% 85mm. We use the 85mm for track days to keep temperatures down. Generally 66% e85 over pump gas. It is $1.80 here now and with our flex fuel kit there's little reason to be on full pump gas unless that's all you have. If we know we'll be doing a good deal of pump gas use we'll switch to the 85mm pulley to reduce knock. Takes all of 3 minutes to switch.
But regardless we've run both sizes on pump gas, though again, we'd strongly advise against doing top-speed runs on the stock motor with the 80mm pulley on pump gas. Just too much heat by the time you get to the top of 5th/6th gear, all of which ethanol negates due to its cooling properties. "Reasonable" driving with pump gas has shown to be just fine on the 85mm pulley. It works on the 80 also, but you have to retard more timing at which point you're better with the bigger pulley and less boost.
At this point we're looking forward to the 335+ upgrade and will hope for 375-400 whp with a fully built motor come spring.
What components does the 335+ have that the regular does not?
Thanks Mike
I'm also interested in eventually running water/meth as I have no access to E85. Only E85 station is a ferry ride away.
You can buy it in cans....
I doubt we'll see it back here. It certainly won't be cheap if it does as the government aren't interested in subsidising it. That's why it disappeared before, it wasn't cost effective.
I would assume storage of this is only safe if you can store it away from your house.
I feel (somewhat) your pain - to my knowledge there are only 2 or 3 E85 stations here in the whole state of Connecticut. I'm "lucky" that one of them is about a 25 minute drive out of my way, but still not realistic for daily - but at least we have 93 octane here.
I'm running 94 Chevron, but would love closer access to E85. Looking at water/meth in the future.
___
My supercharger is going in very soon. Waiting on full exhaust from JDL to arrive. I have read about the debate as to whether an oil cooler is necessary or not on the street and that it might actually hinder performance when not pushing the car to the limits, ie. street driving. Interested in possibly running a Mishimoto oil cooler or Perrin, but not sure if at this point it is a waste of money and should possibly upgrade in the future if I plan on running on the track, etc.
Also interested in everyone's thoughts on upgrade MAP sensor. From what I have read this only applies to turbo applications and is not required for superchargers including the 335 as we are running at a static set boost level.
Chad86 is offline
Old 11-19-2015, 02:31 PM   #440
smudge
Anyone able to post up a dyno plot for a 335 kit on pump gas please?
smudge is offline
The Following User Says Thank You to smudge For This Useful Post:
6-Shift (12-13-2015)
Old 12-26-2015, 11:48 PM   #441
stockysnail
Just the tip
stockysnail's Avatar
@smudge hows the 335 kit with your built motor doing?
stockysnail is offline
The Following 2 Users Say Thank You to stockysnail For This Useful Post:
Chad86 (12-28-2015), sam69 (12-27-2015)
Old 01-12-2016, 02:53 PM   #442
smudge
Not great....will have some updates in the next week or so
smudge is offline
The Following 2 Users Say Thank You to smudge For This Useful Post:
stockysnail (01-12-2016), sw20kosh (01-14-2016)
Old 01-16-2016, 01:27 PM   #443
smudge
Link to the thread explaining my engine failure
http://www.ft86club.com/forums/showt...52#post2511652
smudge is offline
The Following 3 Users Say Thank You to smudge For This Useful Post:
CK_Bladesmith (01-16-2016), Dream20b (01-16-2016), stockysnail (01-16-2016)
Old 01-30-2016, 05:22 PM   #444
jwvand02
Drives: 2013 SWP BRZ Limited
With an 85mm pulley, is there a significant benefit over the 210 with 70mm?
jwvand02 is offline
Old 01-30-2016, 07:01 PM   #445
stockysnail
Just the tip
Around 50ish hp without changing anything else.
See my spread sheet:
https://docs.google.com/spreadsheets...it?usp=sharing
Old 01-31-2016, 12:43 PM   #446
jwvand02
d'oh for some reason I was thinking E85 for the 210 but not the 335 so it's about 45whp and 60wtq when both are on E85.
Any opinions on engine longevity on stock motor with 85mm 335 and E85?
jwvand02 is offline
Old 01-31-2016, 02:26 PM   #447
smudge
A few people on here running 75mm and 80mm on a stock engine with e85 I think
smudge is offline
Old 02-04-2016, 11:51 PM   #448
Dream20b
Y u do dis?
I assume no dyno charts...
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline
500whp or bust, sprintex, sprintex 335
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 12:27 PM
Innovate/sprintex SC rudysaliby Scion FR-S / Toyota 86 GT86 General Forum 3 10-28-2014 04:14 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 24 04-04-2014 03:38 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 08:26 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 08:39 PM
