Old 10-28-2015, 07:53 PM   #421
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by Kodename47 View Post
Wrong
Stats on Shell fuel here are:
99 RON
86 MON
Therefore 92.5 Octane
It's what google told me, so it must be right!
bfrank1972 is offline
Old 10-28-2015, 08:47 PM   #422
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
11,000 MILE UPDATE!!!
Nothing to report
Continues on ticking with no major issues. The new sight glass leaked a bit of fluid so we tightened it back up and no issues. Did some track time in this period and another track day next week, now with an oil cooler and big brakes so it should be less dramatic.
Minimal blow-by from what we see in the radium catch cans.
A few surprised subaru owners who don't understand the merits of instant response in a 60 MPH roll-on...
One surprised owner as to how much the car attracts LEO attention....new radar detector bought.
Otherwise totally issue free since we put this blower on 9 months and 11k miles ago. Even the set of RE-71Rs still has another track day in them. I expected to have been through a trans or some axles by now, but some of that is about how you drive. We regularly utilize our custom RaceROM traction control feature which prevents excessive wheel spin and the subsequent loading that can break axles/gears. Motor is otherwise unchanged in its performance though we will likely build it this winter if we ever finish the WRX.
For those that wonder: Pulley size is about 66% 80mm, 33% 85mm. We use the 85mm for track days to keep temperatures down. Generally 66% e85 over pump gas. It is $1.80 here now and with our flex fuel kit there's little reason to be on full pump gas unless that's all you have. If we know we'll be doing a good deal of pump gas use we'll switch to the 85mm pulley to reduce knock. Takes all of 3 minutes to switch.
But regardless we've run both sizes on pump gas, though again, we'd strongly advise against doing top-speed runs on the stock motor with the 80mm pulley on pump gas. Just too much heat by the time you get to the top of 5th/6th gear, all of which ethanol negates due to its cooling properties. "Reasonable" driving with pump gas has shown to be just fine on the 85mm pulley. It works on the 80 also, but you have to retard more timing at which point you're better with the bigger pulley and less boost.
At this point we're looking forward to the 335+ upgrade and will hope for 375-400 whp with a fully built motor come spring.
Xero-Limit is offline
The Following 8 Users Say Thank You to Xero-Limit For This Useful Post:
8686 (10-29-2015), bfrank1972 (10-29-2015), Chad86 (11-07-2015), Dream20b (11-02-2015), Jmonty (11-08-2015), smudge (10-29-2015), stockysnail (10-29-2015), Toyota86.ir (02-09-2016)
Old 10-29-2015, 02:23 AM   #423
stockysnail
Just the tip
stockysnail's Avatar
Nothing to report
I'm guessing all you have is a stronger clutch then (aside from flex fuel 700cc injectors and larger fuel pump)? If so which clutch? If so I'm definitely doing this next year with tax returns.
I'm also guessing you could do 2 maps one with the 85mm pulley and one with the 80mm pulley, both flex fueled or are two maps even needed? That way once I upgrade I can swap for track days with e85/92oct street (85mm) or street/autox e85 days (80mm)
stockysnail is offline
Old 10-29-2015, 03:30 AM   #424
smudge
Drives: Supercharged GT86
Originally Posted by bfrank1972 View Post
Ballpark it's about 94 octane US, so pretty good.
Eagerly awaiting the return of e85 to the UK...It keeps getting talked about!
smudge is offline
Old 10-29-2015, 03:33 AM   #425
smudge
Nothing to report
Thanks Mike
I'm keen to see what my built motor will run on the 75mm pulley over here in a couple of weeks. And with some testing over winter I think the next step is water/meth injection to keep the temps down without the holy grail that is e85 being available to me
smudge is offline
The Following User Says Thank You to smudge For This Useful Post:
Chad86 (11-07-2015)
Old 10-29-2015, 04:15 AM   #426
Kodename47
Kodename47's Avatar
Drives: UK GT86
You can buy it in cans....
I doubt we'll see it back here. It certainly won't be cheap if it does as the government aren't interested in subsidising it. That's why it disappeared before, it wasn't cost effective.
.: Stealth 86 :.
Kodename 47 DJ:
Kodename47 is offline
Old 10-29-2015, 09:43 AM   #427
bfrank1972
Thanks Mike
I feel (somewhat) your pain - to my knowledge there are only 2 or 3 E85 stations here in the whole state of Connecticut. I'm "lucky" that one of them is about a 25 minute drive out of my way, but still not realistic for daily - but at least we have 93 octane here.
The Following User Says Thank You to bfrank1972 For This Useful Post:
Chad86 (11-07-2015)
Old 10-29-2015, 09:46 AM   #428
smudge
And I bet those cans are a few litres each at best, not exactly practical is it
We have 99RON here which is about 94 octane but e85 is just so much better
smudge is offline
Chad86 (11-07-2015)
Old 10-29-2015, 10:01 AM   #429
Kodename47
Kodename47's Avatar
Drives: UK GT86
Do you ever read/listen!? 99 RON isn't quite 93 Octance!
And E85 cans are done in 25 or 50 litres....
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-29-2015, 11:16 AM   #430
smudge
I thought V-Power was similar to 94 octane?
Might have a search for some e85...
smudge is offline
Old 10-29-2015, 11:49 AM   #431
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
V-power can be 91-93.
Just depends on where you live. V-power is just their marketing term.
Andrew025 is offline
Old 10-29-2015, 12:18 PM   #432
smudge
In the UK it's 99RON, not exactly sure how that translates to octane rating but it's around 93-94 from what I've seen
smudge is offline
Old 10-29-2015, 12:19 PM   #433
8686
8686's Avatar
Drives: 86
Thanks Mike
Very interested to see the results of W/M injection.
Will you use ptuning kit?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline
The Following User Says Thank You to 8686 For This Useful Post:
Chad86 (11-07-2015)
Old 10-29-2015, 12:46 PM   #434
smudge
Not sure what kit we'll use yet - we'll be doing some research over the winter months to see what works best and rest assured it'll be on my progress thread
smudge is offline
The Following 3 Users Say Thank You to smudge For This Useful Post:
8686 (10-29-2015), Chad86 (11-07-2015), sato (10-29-2015)
500whp or bust, sprintex, sprintex 335
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 11:27 AM
Innovate/sprintex SC rudysaliby Scion FR-S / Toyota 86 GT86 General Forum 3 10-28-2014 03:14 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 24 04-04-2014 02:38 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 07:26 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 07:39 PM
