#15 |
Drives: SWP BRZ
Ahh i see, ill try to take a pic of my lca set up sometimes this week. i went to harbor tires for the install.
#16 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
#17 |
Drives: SWP BRZ
#18 |
Drives: SWP BRZ
@solidONE
this is the right side which is where the noise is coming from, today i fiddle around with it and straighten the ball thingy but the noise is still there. |
#19 | |
Intent > Content
#20 |
Drives: SWP BRZ
no i couldnt find anything, im starting to feel it might be the axle but not totally sure.
#21 |
Another thing you can do is with the rear jacked up, kind of rock the tire left to right and up and down to see if it makes any weird clicking noises or have any kind of play where it shouldn't have. Also check the outer portion of the control arm where it's connected to the knuckle if there is any metal to metal contact or play where there shouldn't be (not likely, but might as well check while you're at it). Otherwise the sound might be caused by something else besides the LCA.
Intent > Content
#22 | |
Drives: SWP BRZ
#23 | |
It might be something else making the noise all along. I would say reinstall the stock arms and see if the noise goes away, but if you knew how to do that you probably wouldnt have went to a tire shop to get them installed in the first place. lol sorry buddy.
Intent > Content
#24 |
Drives: Whiteout FRS
I'm guessing that joint does not have enough lube in it between the metal and the rubber so every you're going over a bump, it clunks. Try greasing up the joints. I had a similar clunking issue on my left rear LCA at the same exact location until i massively greased inside that joint and around it. It went away afterwards.
#25 |
Drives: 2013 Satin White Pearl BRZ
Could be the shocks
Sent from my SAMSUNG-SM-G900A using Tapatalk |
#27 |
Brand of air lift struts?
#28 |
| Rear clunking noise when driving | EvoXSwimmer | Issues | Warranty | Recalls / TSB | 4 | 07-24-2017 03:03 PM |
| kw v3 rear making clunking noise | eera | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 12-17-2015 04:10 PM |
| clunking noise after LCA install | starron | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-17-2015 04:02 PM |
| Clunking in rear suspension | toeout | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 01-21-2015 04:11 PM |
| rear rattling/clunking suspension noise | ceebo | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 04-25-2014 10:00 PM |
