Old 10-12-2015, 04:16 PM   #1
dito
Drives: SWP BRZ
Rear suspension clunking noise. Help ):
Hey guys so ever since i installed my pbm lca ive been getting a clicking or clunking noise in the rear. When i had coilovers it wasn't as bad but i still had the noise going uneven pavement or at an angle. I just got my airlift kit installed and now the sound is worse. I get a clunking noise on bumps and everything that isnt flat smooth pavement. The shop tighten all the struts and top hats so it might not be it. I just got an alignment and the shop showed me that my rear sway bar on the left side is pushed out a little bit more than my right. Could this be the problem? Thanks guys
dito is offline   Reply With Quote
Old 10-13-2015, 04:27 PM   #2
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Lowered?
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 10-19-2015, 02:16 AM   #3
wtfrs
Drives: 2014 Monogram
What psi are you driving at in the rear?
wtfrs is offline   Reply With Quote
Old 10-19-2015, 11:41 AM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Clunking when driving can be one of 3 things:
1) loose coilover strut/center nut
2) loose LCA bolts/nuts
3) loose coilover assembly (top hats) or botton mount to LCA
Assuming no defects with your parts... your installer sucks.
-alex
Old 10-19-2015, 11:44 AM   #5
jbailey8748
Rear CV joints can make these noises too
Old 10-20-2015, 03:03 PM   #6
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Check and re-torque all the hardware that you touched during the install.
Intent > Content
Old 10-20-2015, 06:57 PM   #7
mav1178
mav1178's Avatar
Possibly, but usually axles have "click click" noises and it would increase with vehicle speed.
-alex
Old 10-20-2015, 07:16 PM   #8
drift86
Drives: GT86, 22 BRZ
Stock shocks? Stock shocks are prone to leak and cause a clunking sound over bumps. I've had mine replaced under warranty and know of several others with the same issue.
drift86 is offline   Reply With Quote
Old 10-21-2015, 01:33 AM   #9
dito
Drives: SWP BRZ
i had the noise when i was on coilovers too. i started getting the noise after i got my lca installed by a shop that took 2~3 days to install -_-.... so im wonder what is the proper way to tighten the LCA nut and bolts. im driving on 41~43 psi front and 46~48 psi rear.
Old 10-21-2015, 01:58 AM   #10
solidONE
solidONE's Avatar
WTF? that's a 1/2 hour job, maybe 1 hour "book" time. and those tire pressure are way too high. The most I would run, depending on the tire, is 40psi if I'm really trying to save my tires. Scion/Subaru recommends 35psi, IIRC.
Please name the shop that did the install.
Intent > Content
Old 10-21-2015, 04:27 AM   #11
dito
Drives: SWP BRZ
haha my bad the psi are meant for the bags in the air suspension. and yeah the shop kept telling me to come back and forth to install and adjust
Old 10-21-2015, 02:47 PM   #12
solidONE
solidONE's Avatar
PBM as in powered by max? I think I know what's up. lol The locking adjusters on these arms are HUGE. Jack up you car and have a look at where the LCA is connected to the subframe. see if there is any exposed or scored metal on both the subframe and the adjusters. If you find anything like that, then you have located the cause of the noise. haha
You know what? Take some pictures of the mounting points on the subframe/LCA and post them up and I'll show you exactly whats going on. Also, what is the rear camber specs? These arms have a huge range of adjustment. I'm assuming they're designed for "hella" camber adjustment. lmao
Which shop did the install?
Intent > Content
Old 10-21-2015, 02:51 PM   #13
mav1178
mav1178's Avatar
Yup, your installer sucks.
Find someone else to fix your clunking issue.
Old 10-21-2015, 07:03 PM   #14
8R6
8R6's Avatar
Drives: FRS
which shop did the work?
8R6 is offline   Reply With Quote
Rear clunking noise when driving EvoXSwimmer Issues | Warranty | Recalls / TSB 4 07-24-2017 03:03 PM
kw v3 rear making clunking noise eera Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-17-2015 04:10 PM
clunking noise after LCA install starron Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-17-2015 04:02 PM
Clunking in rear suspension toeout Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-21-2015 04:11 PM
rear rattling/clunking suspension noise ceebo Scion FR-S / Toyota 86 GT86 General Forum 8 04-25-2014 10:00 PM
