Old 10-23-2015, 02:33 AM   #15
dito
Drives: SWP BRZ
Ahh i see, ill try to take a pic of my lca set up sometimes this week. i went to harbor tires for the install.
dito is offline   Reply With Quote
Old 10-23-2015, 03:54 AM   #16
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
You had a tire shop do your suspension. I guess I shouldn't be surprised it took them 3 day to do a 1/2 hour job and neither should you...
Intent > Content
Old 10-24-2015, 02:34 AM   #17
dito
Drives: SWP BRZ
... yah LOL
Old 10-24-2015, 11:25 PM   #18
dito
Drives: SWP BRZ
@solidONE
this is the right side which is where the noise is coming from, today i fiddle around with it and straighten the ball thingy but the noise is still there.
Old 10-24-2015, 11:31 PM   #19
solidONE
solidONE's Avatar
@solidONE
Hmm.. looks like they positioned the locking adjusters in the correct orientation for these LCA's were it's least likely to make contact with the subframe. Were you able to find any scored surfaces or any likely points of contact?
Intent > Content
Old 10-24-2015, 11:44 PM   #20
dito
Drives: SWP BRZ
no i couldnt find anything, im starting to feel it might be the axle but not totally sure.
Old 10-25-2015, 12:00 AM   #21
solidONE
solidONE's Avatar
Another thing you can do is with the rear jacked up, kind of rock the tire left to right and up and down to see if it makes any weird clicking noises or have any kind of play where it shouldn't have. Also check the outer portion of the control arm where it's connected to the knuckle if there is any metal to metal contact or play where there shouldn't be (not likely, but might as well check while you're at it). Otherwise the sound might be caused by something else besides the LCA.
Intent > Content
Old 10-25-2015, 04:43 PM   #22
dito
Drives: SWP BRZ
there was one part where we were moving the rear wheel and heard a tick but it wasnt the same sound.
Old 10-25-2015, 11:20 PM   #23
solidONE
solidONE's Avatar
There was no play where the control arm is connected to the hub carrier, subframe, shock, endlink. No contact with the subframe or anywhere else where they shouldn't be making contact nor any signs of it. Every nut and bolt torqued down properly on the control arm, yet it still makes a noise? If that's the case then I don't know what to tell you besides take it to a shop where they have experience with aftermarket suspension. Although they'll probably check all the same things I've told you and maybe try to sell you some new control arms.
It might be something else making the noise all along. I would say reinstall the stock arms and see if the noise goes away, but if you knew how to do that you probably wouldnt have went to a tire shop to get them installed in the first place. lol sorry buddy.
Intent > Content
Old 10-26-2015, 12:18 PM   #24
Bach415
Bach415's Avatar
Drives: Whiteout FRS
I'm guessing that joint does not have enough lube in it between the metal and the rubber so every you're going over a bump, it clunks. Try greasing up the joints. I had a similar clunking issue on my left rear LCA at the same exact location until i massively greased inside that joint and around it. It went away afterwards.
Bach415 is offline   Reply With Quote
Old 10-26-2015, 01:26 PM   #25
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
Could be the shocks
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 10-26-2015, 03:18 PM   #26
dito
Drives: SWP BRZ
I just installed my airlift struts like 3 weeks ago so idk if its the shocks. Where exactly do i grease up the joint @Bach415?
Old 10-26-2015, 03:22 PM   #27
jbailey8748
Brand of air lift struts?
Old 10-26-2015, 03:28 PM   #28
jbailey8748
http://forums.nasioc.com/forums/show...2344218&page=5
Rear clunking noise when driving EvoXSwimmer Issues | Warranty | Recalls / TSB 4 07-24-2017 04:03 PM
kw v3 rear making clunking noise eera Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-17-2015 05:10 PM
clunking noise after LCA install starron Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-17-2015 05:02 PM
Clunking in rear suspension toeout Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-21-2015 05:11 PM
rear rattling/clunking suspension noise ceebo Scion FR-S / Toyota 86 GT86 General Forum 8 04-25-2014 11:00 PM
