Old 10-26-2015, 11:03 AM   #43
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
I'd love to get a 5.10 final drive for my auto.
Freeman is offline   Reply With Quote
Old 10-26-2015, 11:11 AM   #44
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Originally Posted by KVDB31 View Post
There's a gearing difference in the transmission between manual and automatic.
At 3rd gear and above, the changes between gearing, with the same final drive on each transmission, is very apparent IMO. The spacing between each gear is more economy on the A/T for sure
drewbot is offline   Reply With Quote
Old 10-26-2015, 11:12 AM   #45
rx3
Originally Posted by GT86_PRAGUE
Funny, he didnt responded to a single email from me before I called him.
But then it was pretty much smooth and I would buy from him again.
Can you please list what you had to order in order to get this all done, for example:
- Gear
- Seal kit
- Bearing kit
- Shim kit
rx3 is offline   Reply With Quote
Old 10-26-2015, 11:40 AM   #46
GT86_PRAGUE
Drives: GT86
- Gear
- Seal kit
- Bearing kit
- Shim kit
I am not the expert on this, but I would say Gear and Shim kit is a must. Depending on the age and condition of your dif you may need other parts. Just ask Weir or your mechanic what else you need.
Edit: I see you are from Europe, so order the Gear and Shim kit from Weir, you can get the rest from local Toyota/Subaru dealers if needed. Good luck. 4.88 is so awesome.
GT86_PRAGUE is offline   Reply With Quote
The Following User Says Thank You to GT86_PRAGUE For This Useful Post:
rx3 (10-26-2015)
Old 10-26-2015, 09:24 PM   #47
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Does it feel like a stronger pull in each gear? Or is it just a quicker revver?
SUB-FT86 is offline   Reply With Quote
Old 10-26-2015, 11:26 PM   #48
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
Just an update here. I talked to the second shop today and they said "Ya it's pretty fucked up. I'm not sure what they were doing but your gears were cut and everything looks all screwy."
I'm having them take pictures and document it all. Tomorrow it's being sent off to Weir Performance to be rebuilt.
xsnapshot is offline   Reply With Quote
Old 10-27-2015, 03:46 AM   #49
GT86_PRAGUE
Drives: GT86
I have many other mods, but I would say both. It revs faster and also pulls better. Especially on lower gears. It certainly accelerate faster on highway and you dont need to downshift so often but if you did, than it is something new.
SUB-FT86 (10-27-2015)
Old 10-27-2015, 05:06 AM   #50
GT86_PRAGUE
Drives: GT86
- Gear
- Seal kit
- Bearing kit
- Shim kit
Best thread on this topic:
http://www.ft86club.com/forums/showthread.php?p=1275527
Parappa (06-28-2016)
Old 10-27-2015, 05:15 AM   #51
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Jesus Christ, Whats the name of the shop?
I hope your litigation goes well, they should at the very least pay for labor cost and damages i.e. a new final drive from weir
Old 10-27-2015, 12:28 PM   #52
xsnapshot
Fast enough
Last edited by xsnapshot; 10-30-2015 at 03:31 PM. Reason: EDITED for just in case.
The Following User Says Thank You to xsnapshot For This Useful Post:
brianhj (10-28-2015)
Old 10-29-2015, 06:34 PM   #53
xsnapshot
Fast enough
Update:
The shop is not refuting my dispute of the initial install charge. However they are refusing to pay for the parts they Fubar'd. When I told them I would take them to court over it, they called my "bluff" and said "if it comes to that, then fine."
Little do they know it's not a bluff!
Consequently I have spoken with my corporate attorney who has agreed to represent me in this case. I have received my first inspection report back from a local shop here (the diff is on its way to Weir Performance at the moment). The 2nd local shop I took it to basically said they installed was super fucked up. They would also be a witness for my side of the case in court.
Here is what they wrote on their report: (sorry for the all caps)
REMOVE REAR DIFFERENTIAL AND INSPECT
CUSTOMER'S COMPLAINT WAS OF A NOISE COMING
FROM THE REAR DIFFERENTIAL. THE DIFFERENTIAL HAD
BEEN PREVIOUSLY WORKED ON AND CANNOT GET THE
ORIGINAL SHOP TO RESOLVE THE ISSUE. AFTER
CONFIRMATION THAT THE NOISE WAS IN FACT COMING
FORM THE REAR DIFFERENTIAL, WE REMOVED THE
DIFFERENTIAL FOR INSPECTION. AFTER REMOVAL WE
DISASSEMBLED IT AND FOUND SIGNIFICANT DAMAGE TO
THE RING GEAR, RING GEAR PINION, AND BEARINGS. WE
FOUND THAT THE BACKLASH ON THE DIFFERENTIAL
WAS SEVERELY OUT OF SPECIFICATION. THE RING
GEAR/PINION WEAR PATTERNS WEREN'T EVEN CLOSE TO
BEING IN SPECIFICATION. AFTER FURTHER INSPECTION
WE FOUND THAT THE RING GEAR PINION HAD BEEN
EXTENSIVELY MODIFIED FOR NO KNOWN REASON. IT
WAS MODIFIED BY CUTTING THE END OF THE PINION.
THIS MEANS THAT THE RING GEAR AND PINION CAN NO
LONGER MESH TOGETHER. ALSO FOUND THAT THE
PINION WAS MAKING CONTACT WITH THE DIFFERENTIAL
CARRIER. THIS WAS ALL CAUSED BY IMPROPER SET UP
OF THE DIFFERENTIAL. THE PINION SET TOO DEEP INTO
THE DIFFERENTIAL HOUSING WHICH IS WHAT MADE
CONTACT WITH THE CARRIER. THIS COULD HAVE BEEN
PREVENTED BY RESETTING THE PINION. IMPROPER
SHIMS WERE ALSO USED IN THE INSTALLATION.
WITH THE DAMAGE FOUND IN THE CARRIER, THERE IS
NO CORRECTION OTHER THAT COMPLETELY
REBUILDING THE DIFFERENTIAL WHICH WILL NEED A
NEW RING GEAR AND PINION SET, NEW BEARING SET,
SEALER, FLUID, AND SHIM KIT.
Good news is I don't see how I could lose this case. In fact we expect them to settle once they realize I'm not bluffing with taking them to court.
So I am bummed I am still without a car (being repaired...) however... I would be lying if I said I wasn't a little excited about my first court/legal system experience. Especially since I am on the good side of this.
Freeman (10-29-2015)
Old 10-29-2015, 06:38 PM   #54
Freeman
Freeman's Avatar
What's the name of the shop that screwed up the install? And where are they located? Hopefully people we can help people avoid that shop.
Old 10-29-2015, 06:52 PM   #55
xsnapshot
Fast enough
Old 10-29-2015, 07:12 PM   #56
Freeman
Freeman's Avatar
I missed that. Thanks
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 01:49 PM
3.7 Final Drive GsxrMe Engine, Exhaust, Transmission 9 09-28-2015 08:55 AM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 04:11 PM
Final Drive gears?? Nigelr32 Engine, Exhaust, Transmission 41 08-14-2015 04:43 PM
3.3 Final drive? Manji Engine, Exhaust, Transmission 18 01-01-2015 03:51 PM
